Had the oil changed last week at the local oil change joint, and now I'm getting bearing noises at start-up. The level is fine (I dropped about 1/2 quart to facilitate the needed room to pour a can of Restore in).
Would the Restore be causing this?? It's only for a few seconds, then it goes away...
BTW...it's a '89 F-250 with the 302 I think all that info is in my sig.
What oil filter did they put on it , sounds like the anti drain valve isn't working , no oil in filter at start up , put a motorcraft or wix ect filter on it....Lew
agreed! Get a Wix or Motorcraft oil filter... If you don't like doing your own oil changes get a Dorman EZ Drain plug... I don't use any tools for my oil changes! plus you can get way better oil for your engine for the same price!
Yeah your better off changing it your self , or take it to a good shop so you know what your getting , these oil change places just use the cheap stuff . Motorcraft & Wix are good , so are the filters made by champion lab , Mobile I , K&N , are very good ...Lew
Had the exact same issue many years ago with a fram on a 302, knocking on start-up. Replaced with a FL1A Motorcraft on someones advise and sound went away immediately. Find out what brand filter they used!..........Change the oil yourself, NOW! and get that restore crap out of there!
Prior to the oil change, when was the last time the oil was changed? Sometimes old sludgey oil will make the motor quieter (note: I didn't say better) than the fresh oil.
The filter is the Problem dont use anything but a Motorcraft or a wix DO NOT use a FRAM the check in them will make bearing noise at cold start up they are junk!!
Out of curiosity, I have been using Purolator's on all my vehicles. Are they acceptable filters?
