You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
What kind of input does that little LCD screen take?
I'm hoping it's a normal RCA input.
I plan on removing this mirror and installing it into my Mustang. Then installing a backup camera into my Mustang trunklid keyhole. I got my hands on a brand new Taurus auto-dim mirror to replace the Expy one.
I am pretty sure that it is not a standard RCA end. It (the mirror) has a harness that connects to the car. In that harness there should be 3 wires in addition to wires that feed to a non display mirror. These wires should be a video +, video -, and a reverse 12v. The reverse 12volt is what turns on the lcd when the car gets put into reverse.
What you probably have to do is run a wire from the reverse wire in the kick panel to the mirror for power and then cut off the RCA jack to get the outer/inner (+/-) wires and tap those into the mirror harness as well.
There are a lot of shoulds and probablys in my post but I have started doing my homework. I am installing an OEM reverse camera into my 07 expedition which did not come with the wiring for the camera. I am having to run my own wiring because i am going to hook up the camera to the navigation unit and the mirror. I am getting the for sure info on how to wire the mirror, and as soon as i find out I will post again.
__________________
2007 Expedition Limited White Sand
radio shack supposedly sells a video cable with a RCA plug on one end and the split wire on the other. I am planning on checking that out sometime soon.
