You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Well the plates there, but it shows tire size and pressure and vin#, I see at the bottom it says vehicle color, mldg, etc an gear there but its all blank. anywhere else, like under the hood. I checked the glove box, but nothing. I would just like to know, so I have a idea of what size tires I can put on it, its running about 10mph faster then the speedometer right now. Guess I can go by the plate if all else fails.
sounds like you are talking about the tag on the door frame below the striker bolt,it is kinda like a sticker, check on the door itself there should be a metal tag just below the latch that is riveted on unless someone has removed it or the door has been changed and the tag was not switched over to the new door
