Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 01-24-2010, 07:31 PM
scottmeiners scottmeiners is offline
Garage is empty, add now
scottmeiners is starting off with a positive reputation.
scottmeiners
09 Rear Window water leak
Hello,
I have a new to me 09 exp'y xlt and I have noticed that I occasionally have a small water leak from the top of the rear glass. I am only seeing a drop or two, but I don't think something is right. Is this a common problem? Searched the forum and saw a post from an older model exp'y, I'm not sure if the design has changed at all since then or not. should I take it too the dealer? Any suggestions with out taking it to the dealer?
Thanks for your help/suggestions
Scott
  #2 (permalink)
Old 01-24-2010, 08:13 PM
eddiemoney eddiemoney is offline
eddiemoney is starting off with a positive reputation.
Leaking in the glass seal? Or the door?
  #3 (permalink)
Old 01-24-2010, 09:36 PM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
My 07 did this. the seal from the hatch glass door to the weatherstripping is not great. This needs to be adjusted. The dealer can do this.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #4 (permalink)
Old 01-25-2010, 12:04 AM
Tylus's Avatar
Tylus Tylus is offline
Nuke Mechanic
2006 Ford F-250
Tylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud ofTylus has much to be proud of
not a normal issue. I'll bet your weatherseal is pinched or needs to be "fluffed" a bit as berry mentioned.
Let the Dealership fix it up. Shouldn't take them more than 5-10 minutes
__________________
MM1 (SS) - 688 Class - First Flight Tough
2006 F-250 Lariat CC w/PSD <-- Build Thread
2012 Flex Limited <-- 17 mpg city, 27 mpg highway.
  #5 (permalink)
Old 01-25-2010, 10:35 AM
berry1234's Avatar
The rear weather strip is made of a harder material than the other pieces on the car. It's not a good quality to seal out water IMO.
__________________
  #6 (permalink)
Old 01-26-2010, 06:44 AM
nckracer's Avatar
nckracer nckracer is offline
nckracer is starting off with a positive reputation.
My '09 leaked at the top of the rear glass also. The dealer replaced the rear seal but it did not help. How do you adjust the seal to maintain better contact with the glass?
__________________
'11 Explorer Limited 4X4
'09 Expy Limited EL 4X4
'02 F-150 KR Crew 4X4
  #7 (permalink)
Old 01-26-2010, 06:10 PM
IQ9 IQ9 is offline
IQ9 is starting off with a positive reputation.
I have had this "fixed" twice by 2 dealers and it still leaks...not very often but it still happens. I gave up and make sure I coat the seal with 303 every other wash.
__________________
White Sand 08 Expy EL Limited 4x4 with everything but the power running boards & trip tunes.
  #8 (permalink)
Old 01-26-2010, 08:53 PM
buzzard's Avatar
buzzard buzzard is offline
buzzard is starting off with a positive reputation.
Yep it's a very common problem. I had two separate dealerships tell me it was third brake light, but the water is clearly penetrating around other parts of the seal. One dealership actually replaced the the third light assembly. Guess what? It still leaks all around the top of the glass/seal.
I read somewhere the fix is an oversized weatherstrip seal Ford has developed, but neither of the dealerships would listen to me.
__________________
Jim
Mac Haik is a Joke
1968 F250 CS, 390
Pebble Beige/Wimbledon White
2008 4x4 EB Expedition, White
  #9 (permalink)
Old 01-27-2010, 10:33 AM
berry1234's Avatar
Quote:
This is a good idea. I wipe the strip clean with warm wet rag then treat it with some good rubber protectant.
The problem is no doubt the material/size of the strip. Maybe the 2010's have a better one.
__________________
  #10 (permalink)
Old 01-27-2010, 11:14 AM
5.4 Shelby 5.4 Shelby is offline
5.4 Shelby is starting off with a positive reputation.
Must be a Ford thing. My Mustang passenger side window leaks a little bit when I wash it too. Not a lot, but, enough to annoy me.
  #11 (permalink)
Old 04-06-2010, 10:08 PM
2008 Expy El 2008 Expy El is offline
2008 Ford Expedition
2008 Expy El is starting off with a positive reputation.
I had the same problem. It was leaking at the top of the liftgate. The first time they replaced the weatherstrip, still leaked. The second time they made some "adjustments" and leaked even more. The third time I think they finally got it right. They replaced the Liftgate's hinges. They said the hinges weren't closing all the way and the seal between the glass and the weatherstrip was bad. It has only been a week, but so far so good, It poured today and no water!!!
  #12 (permalink)
Old 04-07-2010, 01:06 PM
kenttrudiw kenttrudiw is offline
kenttrudiw is starting off with a positive reputation.
Yes my 07 did this too... My dealer worked and worked and finally replaced the weather strip with a bigger (fatter) one. This has really helped, but my Wife says it is still not perfect either, but livable only a few drops every now and then....
__________________
Colorado
2007 E.B. with a ton of goodies!
  #13 (permalink)
Old 06-26-2010, 09:59 AM
p18303 p18303 is offline
p18303 is starting off with a positive reputation.
Once , Twice, Fifteen times
I had the same problem on my '08 Expedition. I had intermittent, slow water leak from between the top of the hatch glass and the weatherstrip. I have been to the dealer a total of 15 times, and it still leaks. So far they have tried:
1) Change weatherstrip (at least three times)
2) Make "adjustments" (numerous times)
3) Change out the glass window.
4) Change out the entire hatch assembly.
5) Bend out the flange on the hatch.
Guess what... still leaks. They told me that they never heard of such a problem before.
I have considered just caulking the hatch window shut and disengaging the latch, so it will never open - but I am concerned about dirt/leaves/debris building up in the dead space, which can lead to rust and corrosion - if I seal the window shut.
  #14 (permalink)
Old 06-26-2010, 12:10 PM
radzer0 radzer0 is offline
radzer0 is starting off with a positive reputation.
Tell them you want to have a ford engineer look at it and find out whats wrong. They will setup a date for when he is at the dealership for you to bring it in.
  #15 (permalink)
Old 06-26-2010, 12:20 PM
scottmeiners
Mine we leaking pretty much this winter, but since it has gotten hot arround here, I have not noticed it leaking at all. So I will probably just wait until the winter to finally bring it to the dealer. Unless I bring it in for something else.
Tags
08, 2005, expedition, f150, ford, leak, leaking, leaks, leaky, rear, recall, seal, trucks, water, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
