Job 1, Job 2...? - Ford Truck Enthusiasts Forums
6.4L Power Stroke Diesel Engine fitted to 2008 - 2010 F250, F350 and F450 pickup trucks and F350 + Cab Chassis
Job 1, Job 2...?
Old 01-24-2010, 06:59 PM
lawnspecialties lawnspecialties is offline
lawnspecialties is starting off with a positive reputation.
Job 1, Job 2...?
I'm looking at purchasing an '08. I have two picked out and they both have 75,000 miles. Both are Lariats and both are priced almost identical.
Truck 1 was manufactured in 3/07. It also has navigation, sunroof, and the shorter front air dam.
Truck 2 was manufactured in 8/07. It doesn't have navigation or sunroof but it does have the taller air dam.
On another forum site, multiple members refer to Job numbers of their trucks. Supposedly, Job 1 trucks have the shorter front air dam while Job 2 models have the taller air dam. It's of their opinion that Job 1 trucks have more problems; especially with the radiators.
So...
1. Is there a tried and true way of telling which Job number a truck is?
2. Is it really a big deal?
3. Since price is virtually the same, is buying a Job 2 truck better than a Job 1 truck, even though the Job 1 truck has the navigation and sunroof?
Thanks
Old 01-24-2010, 07:47 PM
ruschejj's Avatar
ruschejj ruschejj is offline
ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.ruschejj has a spectacular reputation.
My job 1 has radiator problems. Otherwise, it's been very solid. I have 121,000 miles on it.
Job # dates for the '08 model year are listed in the 6.4 Tech Folder. Go check it out, there is also a summary of the changes listing the job 1, 2, 3.
I purchased the tall air dam used from somebody here on FTE that did'nt like it. Some say that it can give a 1 mpg gain if you drive interstate a lot.
I would get an OASIS report on both trucks and then buy the one you like and not look back. I have a co worker with a job 2 truck identical to mine, he had his engine replaced due to a blown EGR cooler.
Old 01-24-2010, 08:32 PM
senix's Avatar
senix senix is offline
senix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputationsenix has a superb reputation
I'm a job 3...I had a bad TCM at 600 miles, but other than that just fine. Don't think the job #'s are that important this late in the game.
Rather look at the OASIS reports and inspect/drive the truck very carefully to insure a good purchase.
Old 01-24-2010, 10:49 PM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
see the 6.4L Diesel: 6.4 Tech Folder topic at the top of this forum, and directly here
http://www.ford-trucks.com/forums/81...ml#post6392540
Sam
Old 01-25-2010, 07:52 AM
Thanks for everyone's help. I've learned quite a bit. I never knew about the tech folder. Maybe because I've never looked.
Like ruschejj said, "I would get an OASIS report on both trucks and then buy the one you like and not look back".
Thanks again.
Old 01-25-2010, 08:18 AM
sdetweil's Avatar
Also, I bought a used 08 F350, Job 1 (built 4/07) with 45k miles in Sept 09.. It had the radiator problem prior to my purchase (showed on the Oasis report).
Sam
Shorter Front Lower Air Dam (valance) 2017F250 2017 Super Duty 4 01-03-2017 09:58 AM
Front Air Dam on 93 F-150 Fordication 1987 - 1996 F150 & Larger F-Series Trucks 10 04-17-2016 09:07 PM
CCD SUSPENSION RUBICON 2015 + Expedition & Navigator 13 03-10-2015 08:48 AM
Dam. Double Dam. Y2KW57 1999 - 2003 7.3L Power Stroke Diesel 29 05-12-2014 11:50 PM
Air dam question Ford8544 6.4L Power Stroke Diesel 36 03-08-2008 10:33 AM
Tags
08, 1, 2, 2008, 64, dates, f250, f350, ford, job, number, numbers, powerstroke, problems, truck, versus
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
