Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1961 - 1966 F-100 & Larger F-Series Trucks > 1961 - 1963 F100 Unibody
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1961 - 1963 F100 Unibody 1961, 1962 and 1963 Ford F100 Unibody trucks
  #1 (permalink)
Old 01-24-2010, 05:07 PM
unibody62's Avatar
unibody62 unibody62 is offline
Garage is empty, add now
unibody62 is starting off with a positive reputation.
Craigslist 4x4 unibody?
This unibody is on craigslist. Did Ford even make a unibody 4x4? I bet it's a transplant.
1962 Ford F-100 Unicab Shortbed 4x4
__________________
1962 F100 Unibody
1969 Thunderbird
1995 F150 4x4
2010 F150 4x4
  #2 (permalink)
Old 01-24-2010, 06:15 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by unibody62 View Post
This unibody is on craigslist. Did Ford even make a unibody 4x4? No. I bet it's a transplant.
NOT Genuine Ford.
It's something a previous owner put together. The EZ way to tell is: This 4WD truck has 2WD front fenders.
1961/65 F100/250 & 1966 F250 4WD's use different front fenders than 2WD's.
The 4WD fenders have a larger opening radius: 45" compared to the 2WD fenders that have a 36" opening radius.
When these trucks are converted to 4WD, they have to be lifted up for additional clearance.
1966 F100 4WD's use 2WD front fenders because these trucks were lifted at the factory.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
  #3 (permalink)
Old 01-25-2010, 01:07 PM
unibody62's Avatar
[quote=NumberDummy;8415004]NOT Genuine Ford.
Interesting observation. I guess I've never seen the wider openings. It seems like it would be hard to notice from the pictures posted.... not close enough for me. I'll have to try to find a true 4wd to compare.
__________________
1962 F100 Unibody
1969 Thunderbird
1995 F150 4x4
2010 F150 4x4
  #4 (permalink)
Old 01-25-2010, 01:40 PM
cobraguy cobraguy is offline
cobraguy is starting off with a positive reputation.
Ford NEVER made a "production" 4X4 unibody.
__________________
62 Falcon 2dr
63 Ranchero
01 Saturn SC1 plastic Vega
11 Kia Forte 5
3 Bikes
  #5 (permalink)
Old 01-25-2010, 05:54 PM
garbz2's Avatar
garbz2 garbz2 is offline
1963 Ford F-100
garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.garbz2 has a great reputation on FTE.
You can also notice the front axle is wider with the same rims front and back.
__________________
98 528I BMW
64 F100 "Christine II" 390 NP435 6" lifted 2 wheel drive
63 F100 Uni Custom under construction 4" off the pavement and built to drive.
69 M250 Crew Hiboy 472 C6 Ranger, getting a full rebuild.
  #6 (permalink)
Old 01-25-2010, 06:12 PM
Back265's Avatar
Back265 Back265 is offline
Back265 is starting off with a positive reputation.
Isn't the price kinda high? If there is not a trany or transfer case ..... factory 4x4 with matching gears. No motor, transmission or transfer case. .... what gears is he referring to?
  #7 (permalink)
Old 01-25-2010, 06:35 PM
Ford Parts Guru
2013 Ford Escape
C2TZ16005D .. R/Front Fender // C2TZ16006D .. L/Front Fender / 45" Opening Radius
Fits: 1961/65 F100/250 4WD / 1961/66 F350 / 1966 F250 4WD.
Looking at the right or left side of the truck...compare the opening radius of the 2WD fenders to the 4WD/F350 fenders where they meet the doors.
The difference is very apparent.
Quote:
Originally Posted by Back265
What gears is he refering to?
The ring & pinion gears. The front driving axle and the rear axle ratios match.
__________________
  #8 (permalink)
Old 01-25-2010, 06:58 PM
garbz2's Avatar
1963 Ford F-100
Well almost match. a ford factory will be 4.10 rear and 4.09 front.
Why I dunno....
Garbz
__________________
98 528I BMW
  #9 (permalink)
Old 01-25-2010, 07:03 PM
Old_Crow's Avatar
Old_Crow Old_Crow is offline
Old_Crow is gaining momentum as a positive member of FTE.
Garbz, the difference in the ratios is to allow the front end to pull just a little bit more than the rear for directional stability. Also one of the reasons you're not supposed to run in 4wd on clean dry roads.
  #10 (permalink)
Old 01-25-2010, 07:06 PM
garbz2's Avatar
1963 Ford F-100
I was playing dumb......But great info. It also allows the front to track at a slightly faster speed in turn just like a regular 2 wheel drive, due to shorter radius.
Garbz
__________________
98 528I BMW
Tags
1962, 1963, 1966, 1969, craigs, craigslist, f100, f250, fender, fenders, ford, list, pic, truck, trucks, unibody
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
