Battery light on, but alternator is charging??? - Ford Truck Enthusiasts Forums
1999 to 2016 Super Duty 1999 to 2016 Ford F250, F350, F450 and F550 Super Duty with diesel V8 and gas V8 and V10 engines
Old 01-24-2010, 04:49 PM
saleen065 saleen065 is offline
saleen065 is starting off with a positive reputation.
OK I have 14.04 volts at the batteries with the engine running but my battery light is on. I had the alternator checked off the engine and on the engine and it tests good. Shows good batteries and good charging. Is there something internal to the alternator that would make the light come on even though the alternator is charging ok? Or is there something else that would make the light come on. This is on a 1999 F250 Superduty Powerstroke 7.3. I'd appreciate any help. I did the search function on here but am still not clear as to the problem.
George
Old 01-24-2010, 05:40 PM
ReAX's Avatar
ReAX ReAX is offline
ReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to beholdReAX is a splendid one to behold
Power is sent from the battery to the key and then into the coil of the alternator. Then 12v is sent through the dash bulb and into the alternator. If the alternator has 12v on the coil and the bulb has 12 going into it, then both sides of the bulb have 12v + and no flow so no light. If the cluster is shorted out then voltage can come the bulb and light it, or it the coil is not energized, voltage can go through the bulb and light it.
Old 01-24-2010, 06:02 PM
The coil you are referring to is a coil within the alternator?
Old 01-24-2010, 06:46 PM
ReAX's Avatar
Yes. There are a couple of coils inside the alternator. I'm not very up on how it works, but here's some idea. An outer coil is charged to create a magnetic field, then the armature is spun and starts pushing electrons around and creates an AC voltage(something like 30vac). That voltage is rectified in 12vdc which is what you want. Without the extra magnetic field you don't get the high voltage AC and I believe it either reduces the amperage or the DC volts depending on how power hungry the rest of the system is.
Old 01-24-2010, 07:03 PM
OK thanks, so if I have 12V on one of the small wires and do not have 12v on the other small wire with the engine running, the light is on. If 12v on both wires than I shouldn't have a light. That's how I think I understand it, right?
Old 01-24-2010, 10:43 PM
ReAX's Avatar
I believe there are three pins in the pigtail. However if it's like the gas alternator, no wires in the middle because it's internally grounded to the alt case. So if you have 12v on both wires, then the alt isn't the cause of the light. Now I think I recall there being a low voltage drop to trigger the light, you must have atleast 5v or 7v to keep the light from coming on.
Old 01-24-2010, 11:24 PM
redford's Avatar
redford redford is online now
redford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputationredford has a superb reputation
I would suspect the alternator. Inside are 6 diode. The AC current produced by the alternator is run through the diodes and it becomes DC current. If 1 or more of these diodes go out you'll still get some output but not as much current. During episodes of higher electrical demand the current cannpt go up, so the voltage goes down. which is triggering your light.
Have your alternator retested. Hopefully the shop testing it will spin it up and put a load on it. If it still passes take a close look at your battery cables and battery,
Old 01-25-2010, 07:16 PM
ReAX's Avatar
Do you have a diagram of a six diode rectifier? I've only seen 4 diode bridges.
Old 01-25-2010, 08:02 PM
bohiaa bohiaa is offline
bohiaa is starting off with a positive reputation.
Start the truck.... while it's running pull the postive connection off the battery.
If the truck stays running. the alt. is GOOD.
if NOT replace the alt.
Old 01-25-2010, 08:06 PM
ReAX's Avatar
The problem with that is it can cause a voltage spike that could damage the computers. It's not terribly likely, but something to be concerned about.
Old 05-25-2011, 08:22 PM
belz's Avatar
belz belz is offline
belz is starting off with a positive reputation.
Hate to bring this back up but now I am having the same problem. Did you ever get this resolved? And if you did what was the problem? I will go out and test the alt plug right now and when I pass by the auto parts store I will have them bench the alternator.
Old 05-26-2011, 09:19 PM
Dave Tyler Dave Tyler is offline
Dave Tyler is starting off with a positive reputation.
I too am having this problem, then after awhile the light went off. Also 1999 with 210,000. If I do replace the alternator, what is the difference between the high output vs the regular? mIs it worth the difference in price? No amp but pull travel trailer and other water trailer. Appreciate the input. Dave
Old 05-26-2011, 11:45 PM
redford's Avatar
If the standard alternator worked OK for 210k miles, there is no need to upgrade to a higher output alternator.
Old 05-27-2011, 01:34 PM
Thank you for your response. It is folks like you that make this forum. I appreciate your responses and know others do too! Regards. Dave
Cleaned cables and all last night and light was off for about 15 miles this morning and then came back on. Hope to make it home.
Old 04-27-2013, 07:12 AM
95250mac 95250mac is offline
95250mac is starting off with a positive reputation.
When I replaced my exhaust manifold I had the batt. light come on, then I cleaned up the cable that goes from the truck body to the manifold stud and the light went away.
Just the other day I checked the manifold bolts and made sure they were all tight, and now as of yesterday the batt. light is coming on again.
I have not had a chance to re-check the cable but I am going to and when I do I will let you know the outcome.
2006 F350 Super Duty Alternator scottsmith 6.0L Power Stroke Diesel 103 04-04-2016 05:22 PM
no battery light / no charge maxtruck00 6.0L Power Stroke Diesel 2 07-18-2015 05:32 PM
alternator fuse? chadc281 1999 to 2016 Super Duty 12 05-15-2015 02:04 PM
Alternator Problems. Help. Shutech 1999 to 2016 Super Duty 1 04-21-2015 10:31 PM
Battery not charging & no alternator light highgearonly 1987 - 1996 F150 & Larger F-Series Trucks 5 01-30-2006 08:58 AM
Tags
1997, 2002, 73, 99, alternator, battery, charging, dash, f150, f250, ford, good, light, powerstroke, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
