2007 - 2014 Expedition & Navigator 2007, 2008, 2009, 2010, 2011, 2012, 2013 and 2014 Ford Expedition and Lincoln Navigator
Power folding mirror swap
Old 01-24-2010, 02:03 PM
ZFamly's Avatar
ZFamly
ZFamly is offline
I have an 07 EB EL. I want to replace my side mirrors with mirrors off of the Limited model. The Limited model mirrors are power folding. The wire harness is the exact same. The only difference I can see is the switch on the door panel. To operate the folding of the mirrors you press the switch down. The switches are almost identical. My switch doesn't show the folding option. I'm sure the mirrors would probably work but will I have to change the switch to the Limited one. Thanks
Old 01-24-2010, 06:43 PM
Tylus's Avatar
Tylus
Tylus is offline
MMNC (SS)(Ret)
all you need is that switch...and you might already have it.
the switch actually gets "pulled" backwards when it is in the neutral position. that triggers the mirrors to fold or extend.
depending on the wire harness, you will need to run a trigger wire from the adjustment switch to the mirror. relatively easy though.
btw, when you install them, there is a synchronization procedure inside the owners manual. make sure to do this. it sets the power fold mirrors up so they fold and extend the proper amount and do it in sync
Old 06-10-2010, 12:29 PM
bubbalet's Avatar
bubbalet
bubbalet is offline
Expedition tow mirror swap
Hi Zfamly. Just curious what year of limited F-150 did you get the power fold tow mirrors from? Im looking at doing the same thing.
Old 06-11-2010, 08:24 AM
CarbonClear's Avatar
CarbonClear
CarbonClear is offline
Yes....Thats a great idea! I would be interested as well. Also any pics of removal and install would be nice as well
Old 08-26-2010, 02:06 PM
hjsimpson's Avatar
hjsimpson
hjsimpson is offline
Any progress on this project?
SUPERDUTY_08
1999 to 2016 Super Duty
21
02-19-2022 09:26 AM
MikeRizz
6.4L Power Stroke Diesel
04-19-2021 02:18 PM
dvldog13
6.7L Power Stroke Diesel
03-21-2017 09:17 PM
Byron W
2009 - 2014 F150
05-10-2012 08:43 PM
Ragzz
03-05-2012 03:03 PM
Quick Reply: Power folding mirror swap
