75 Highboy F250 Standard Cab Short bed? - Ford Truck Enthusiasts Forums
Old 01-24-2010, 02:48 PM
Gofazt2's Avatar
Gofazt2 Gofazt2 is offline
Gofazt2 is starting off with a positive reputation.
Hello Everyone,
I seen a truck the other day that I did not think existed. It was what appeared to be a 1975 F250 Highboy standard cab short bed. It had the 8 lug D44 and D60 with a divorced np205. It also had the granny low 4spd. The only think odd was that someone had swapped in a 302 which was obvious that it was swapped but did not appear that the rest of the drivetrain had been swapped.
Are these common? I was just curious since I had not seen one. Let me know what you think.
Thanks,
Chad T.
Old 01-24-2010, 02:57 PM
ranger429 ranger429 is offline
ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.ranger429 has a good reputation on FTE.
Never produced by Ford, no 3/4 or 1 ton shortbeds in a regular cab version.
Old 01-24-2010, 06:34 PM
Blown 331's Avatar
Blown 331 Blown 331 is offline
Blown 331 is gaining momentum as a positive member of FTE.
My uncle actually has about a 1963 F-250 4x4 short bed standard cab. I think he said it was a military issue or something, its an awesome truck. Needs a lot of work but does run, too bad its sitting outside. I can get the VIN if anyone is interested.
Old 01-24-2010, 06:35 PM
montana_highboy montana_highboy is offline
montana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud ofmontana_highboy has much to be proud of
No such animal (from the factory anyway) sounds interesting though.
Old 01-24-2010, 08:54 PM
Gofazt2's Avatar
Does the VIN have a special charicter for a Highboy?
I assume they did not make a F150 Highboy...correct?
The badges are missing on this truck and that is why I was asking.
It has all the correct steering components with the correct Highboy front end. Someone would have gone through a lot of trouble to switch all the crap over to a short bed chassis.
I am going to try and get the vin off the truck and see what it will tell me. I will let you know what I find out.
Thanks,
Chad T.
Old 01-24-2010, 09:28 PM
Quote:
There is no special character in the VIN to designate a Highboy. You can do a search for VIN numbers and the VIN break point has been discussed before
Correct, only Highboys were on a 250 chassis.
Someone could of shortened the frame. I knew a guy back in the 80's that shortened a 3/4 ton 79 to make it a shortbed.
Thanks,
Chad T.
Old 09-17-2015, 11:30 PM
Lee Ketchemonia Lee Ketchemonia is offline
Lee Ketchemonia is starting off with a positive reputation.
tow truck !
I just bought one today. It was a tow truck. It needed a short wheel to fit the tow truck attachment. It is factory built. I'm currently taking off the attachment.
Old 09-18-2015, 12:24 AM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Ford did not build an F250 with a short bed PERIOD!
If the truck was purchased as a Cab & Chassis (no "back of cab equipment"), the first 3 digits of the VIN: F28 = F250 4WD Cab & Chassis.
If you look on the Warranty Plate for the DSO code and it has 6 digits, Ford sent the truck out after it left the assembly line, per the original purchaser orders, to have the tow truck body installed.
If the original purchaser specified a shorter wheelbase than the standard 133" wheelbase (Regular Cab), then the frame was modified by the body company, making the truck a Domestic Special Order.
Old 09-18-2015, 08:17 AM
scott79's Avatar
scott79 scott79 is offline
scott79 has a good reputation on FTE.scott79 has a good reputation on FTE.scott79 has a good reputation on FTE.
Yes they did, F250 Crew cabs came with shortbeds!!
Old 09-18-2015, 08:25 AM
Quote:
You are correct that Crew Cabs did. I was thinking of regular cabs and cab & chassis regular cabs that the fellow that has a tow truck claims that Ford assembled with a short bed.
Old 01-29-2016, 09:02 AM
SRF14405DESIGNER SRF14405DESIGNER is offline
SRF14405DESIGNER is starting off with a positive reputation.
Hello everyone. I have to agree. They did not build (at the factory) any shot bed Highboy reg. cabs. Not to say some body builder didn't modify some cab and chassis. Other issue I have the engine sizes in these trucks...They did not build a highboy with a 460!!!.
E4OD to ZF 5S-42 swap break down myakkacracka Clutch, Transmission, Differential, Axle & Transfer Case 13 06-16-2016 12:33 PM
That guy with dumb questions! FuzzFace2 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 15 05-21-2016 10:53 PM
What propshaft to use? (4x4 swap) Truckandute 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 08-28-2014 02:42 PM
73-79 parts scott78f2504x4 Ford Truck Parts for Sale 54 08-25-2014 07:26 PM
HELP!! Truck runs for 45 mins then starts to sputter and die K8's Ford 1987 - 1996 F150 & Larger F-Series Trucks 13 10-19-2010 06:39 PM
Tags
1977, 1979, 79, bed, black, boy, cabs, f150, f250, ford, frames, high, highboy, short, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
