You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
I've got a '79 F-150, and have finally gotten to the point of wanting/needing to rebuild (or replace?) the drivetrain on my truck.
Does anyone have any recommendations for a engine and transmission builder in the Huntsville/North Alabama area?
I'm looking to keep this as a daily driver, but beef it up quite a bit. I'm considering asking Tim Meyer to build a 434 Stroker for me and then swap it out when it gets here, unless there's someone just as good here!
I'm had my engine work done at Performance Specialties Inc (205-841-7790) in Birmingham. The owners names are Rick Pennington and Al Moore. They did an excellent job for me. They do all the machining, balancing and dyno work in house. My engine was a 351M and we used Tmeyer's 400 pistons, .030 overbore with a 400 crank to get 408c.i.. We used an Edelbrock 400 intake, Comp 255deh cam and a 600cfm carb with headers and it dyno'd at 339hp@4300 and 478ft/lbs@2900. Obviously this is a mild build compared to a stroker 434, but was a huge difference in original form. I know it would be little bit out of the way from Hunstville area.
My transmission work was done by Performance Torque Converters (www.ptcrace.com) in Muscle Shoals (256-383-6868). They do a professional job and after rebuild they dyno your transmission to make sure the pressures and shift points are correct.
I hope this helps you some.
__________________
1979 F100 Ranger, 351M/408c.i., Tmeyer pistons and eng. kit
Engine work by Performance Specialties Inc., B'ham, Al.
C6 by Performance Torque Converters, Muscle Shoals, Al.
Engine Dyno'd - 339HP@4300rpm, 478FT/LBS@2900rpm
That's good info...thanks! I'll definitely look up PTC for my C6. I've just got to figure out how heavy I want to go on the engine rebuild/replace. Your route sounds awesome! I'm a little wary of the lack of Huntsville-specific recommendations for engine builders, both from FTE and folks I've asked about in person. Fultondale may not be too far of a reach. Thanks again!
You're welcome. Good luck with your build.
Just a suggestion, try asking the folks at PTC for reliable engine builders in your area. They deal with alot of the racers and they should be able to get some leads.
__________________
I have a standard bore 460 block sitting in my shed you can have if you'd like
__________________ WAR EAGLE!!!
1979 F100 SWB:
To come: 5.4 DOHC w/twin turbo, Tremec TKO 600, 04 CVPI front suspension/ Mark VIII rear axle, and other stuff. Pro-touring, anyone? Want to join the Alabama chapter? CLICK HERE!
