4.9L Replacing Lifter Gallery Gasket- Tough Job? - Ford Truck Enthusiasts Forums
Old 01-23-2010, 04:31 PM
Elton Noway's Avatar
Elton Noway Elton Noway is offline
Elton Noway is starting off with a positive reputation.
Question 4.9L Replacing Lifter Gallery Gasket- Tough Job?
The lifter gallery (pushrod cover gasket) on my 1990 F150 (inline 6 cylinder 4.9L) has been leaking more and more oil. Its time to replace it. (BTW... I'm sure its the lifter gallery cover and not the head gasket.) To make sure... I first steam cleaned the engine. Once clean ... I fired it up for about a minute then shut it off. There was the leak, in plain site... leaking out from bottom front edge of the lifter gallery cover.
I'm debating on doing it myself or taking it to a shop. I usually do all my own maintenance. (Replaced radiator, water pump, starter, alternator, brakes, etc etc... no problem.)
However... the lifter gallery gasket seems trapped behind the coil and distributor... (not to mention a huge wiring harness). It appears the wire harness will lift out of the way once I unbolt the clamp. I guess my main concern is if I can get the cover and the new gasket in place without damage to the gasket. The space between the gallery cover and back side of the distributor and coil is very tight (only about 3/4 inch) I don't want to pull the distributor or the coil.
I was wondering if any of you had any tricks or warnings prior to beginning the project or if I should let a shop do it.
I'm including some pics because my 1980 -1994 Haynes manual does not identify the name of the cover / gasket. It took me some time surfing the web to discover it was the lifter gallery cover. DOH! Very obvious once I figured it out.
Old 01-23-2010, 04:50 PM
Lone Wolf #2 Lone Wolf #2 is offline
Lone Wolf #2 is starting off with a positive reputation.
You shouldn't need to pull the dizzy but pulling the coil will make things much easier as there should be a bolt right behind the coil & bracket. The coil isn't that hard to pull, just two bolts if I remember right. When you get everything off and cleaned putting the new gasket and cover back on will be much easier and result in much less use of four letter words if you use something to stick the gasket to the cover (Indian Head, Permatex, something sticky.) If I remember right, when I did this on my 74, the gasket was a touch long. That may have just been the gasket brand though.
Old 01-23-2010, 05:00 PM
BigBlueOx's Avatar
BigBlueOx BigBlueOx is offline
BigBlueOx has a very good reputation on FTE.BigBlueOx has a very good reputation on FTE.BigBlueOx has a very good reputation on FTE.
I agree with the above post. I used permatex spray-tack to get the gasket to stick to the cover. Not a hard job......just maticulous and time consuming. Have patience dude, you can do this.
Old 01-23-2010, 07:33 PM
fishforlife2007's Avatar
fishforlife2007 fishforlife2007 is offline
fishforlife2007 is starting off with a positive reputation.
i need to do the same to my 4.9....just holdin out for spring when its warmer! good luck with it man!
Old 01-23-2010, 07:59 PM
V1GiLaNtE's Avatar
V1GiLaNtE V1GiLaNtE is offline
V1GiLaNtE is starting off with a positive reputation.
You can do it.. like stated it takes a little patience but I was able to do it by just removing intake ducting.. loosing the intake mainfold and I left the distributor in... Time consuming but I would recommend while you're in there may want to consider changing the intake and exhaust maniflold gasket??
Old 01-23-2010, 08:18 PM
KC92F150 KC92F150 is offline
KC92F150 is starting off with a positive reputation.
Did you try tightening the covers up? Mine were leaking on my 92 4.9L and I retorqued them and the leak quit. I guess I was just lucky...worth a try though. Good Luck
Old 01-23-2010, 08:34 PM
why would you change the intake and exhaust manifold gasket that is on the complete other side of the engine?
Old 01-23-2010, 11:37 PM
Wow! I want to thank everyone who replied. I never expected such a response... or so quickly!
Based on all the feedback I ran out and purchased the gasket, some Permatex, and engine degreaser (it needs it due to the leak).
I can live with the job being tedious... and I have no problem busting my knuckles. What I didn't want to do was get upside down in a dismantle.
I've rebuilt my share of engines but I was much younger then. I need my truck to get to work on Monday and since I was looking at doing the job tomorrow (Sunday) I wanted to make sure I wouldn't run into any hidden surprises.
I've made up my mind (based on everyone's feedback) to forge ahead. I'll check back in tomorrow afternoon once the job is behind me. Thanks to the tip from Lone Wolf #2 about pulling the coil. In looking at it this evening I does appear to be straight forward and will certainly give me more room to work.
Quote:
Originally Posted by KC92F150 View Post
Did you try tightening the covers up? Mine were leaking on my 92 4.9L and I re-torqued them and the leak quit. I guess I was just lucky...worth a try though. Good Luck
Yep... tried that already. Believe me I wanted that to work more than anything. Last weekend I discovered two of the bolts near the area of the leak were so loose I could spin them with my finger tips... however... even after tightening all the bolts (in alternating sequence and being careful not to torgue them down to tight and warp the cover)... it still leaked. FYI: Leak might be too generous of a term. Flood would be more accurate. When I shut off the engine, oil literally pours off the bottom of the engine onto my driveway in a steady stream for a good 15 seconds or so. Its leaking about 1 Quart every 15 miles. I can only guess what's going on as I fly down the highway. Cars that were unfortunate to have followed behind are probably wondering what the oily film is that is smearing their windshield.
Old 01-24-2010, 12:23 AM
fordman1090 fordman1090 is offline
fordman1090 is starting off with a positive reputation.
i did that a couple years back. I got it done in just a couple hours, you dont have to remove to many accessories. I didnt think it was to bad. And it hasnt leaked a drop since then.
Good Luck
Old 01-24-2010, 08:17 AM
Silent Bob Silent Bob is offline
Silent Bob is starting off with a positive reputation.
I replaced mine a few years back. I think there were a couple of things that had to be moved out of the way, but there was nothing at all difficult about it.
Old 01-25-2010, 10:14 AM
jas88's Avatar
jas88 jas88 is offline
jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.jas88 has a great reputation on FTE.
NITPICK ALERT (but this site is here to educate, right?): It's "lifter galley", not "lifter gallery", and really only applies to V-type engines. On your six, that is called a "lifter cover gasket".
Old 04-03-2010, 11:50 AM
Love_my_Ford_POS Love_my_Ford_POS is offline
Love_my_Ford_POS is starting off with a positive reputation.
Thanks all for the postings, I'm another '92 owner that has a massive oil leak from the lifter cover. It sounds doable. So, no need to pull the power steering pump?
Cheers!
Old 04-03-2010, 05:37 PM
86f350's Avatar
86f350 86f350 is offline
86f350 is starting off with a positive reputation.
I also need to do this: thanks "Jas88" I didnt know what it was called but I do now.
Old 04-16-2010, 03:32 PM
Replacing Lifter Gallery / Galley Gasket
Sorry for the delayed followup... but thanks to all the tips, advice and encouragement I received from members of this forum I felt it was my obligation to let everyone know I went ahead and replaced it on my own.
As pointed out by several members, the job wasn't that bad. Just time consuming. I "did not" pull the distributor... but I did remove the distributor "cap". Removing the cap gave me the extra room I needed. With the cap off I was able to move all the distributor wires back away from the work area making it easier to get the cover off and back on. I also had to remove the coil becuase it was held in place by one of the galley cover bolts. Anyway, as long as I had the coil off... I went ahead and replaced it (it was less than $10).
As it turns out the original cover gasket had a bad spot in the seal. Since I'm the original owner of the vehicle and I've never replaced this gasket before it had to have some this way from the factory. I'm surprised it held to 170K miles before springing a leak.
Showing Cover Removed
Showing bad spot / Area of Leak!
New Gasket!
Old 04-16-2010, 03:37 PM
86f350's Avatar
Elton : glad to hear you got the leak all taken care of....now maybe ill take the leap and do mine as well. Whats the part number for the gasket from CarQuest ? thanks
Finally... New owner of 2003 Excursion 6.0L - Rebuild progress shurik74 Excursion - King of SUVs 31 Today 02:13 PM
2006 Ford F-350 King Ranch (DRW) SOLD! toyomatt84 Vehicles for Sale 3 07-19-2016 01:25 AM
It's time to play What's That Wire! Glowplugger 1999 - 2003 7.3L Power Stroke Diesel 11 03-21-2015 11:54 AM
Beach wheeling sammatt1 Excursion - King of SUVs 11 09-02-2014 05:23 PM
My new F150 SquattingBear 1987 - 1996 F150 & Larger F-Series Trucks 123 12-20-2013 10:05 PM
Tags
300, 49, 49l, buy, ci, engine, f150, ford, gallery, hydraulic, lifter, lifters, replacing, straight, truck, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
