2001 F150 Fuse Box Diagram - Ford Truck Enthusiasts Forums
Old 01-23-2010, 02:57 PM
PolegoJim PolegoJim is offline
PolegoJim is starting off with a positive reputation.
I just bought an 01 F150 and previous owner didn't have the manual.
Does anyone have a copy of the fuse box diagram for this truck?
If so, could you post here or email to me @ polegojim@gmail.com?
I've been surfing the net, and can't find what looks like the right one.
Thanks
Old 01-23-2010, 05:25 PM
Ron W.'s Avatar
Ron W. Ron W. is offline
Ron W. is starting off with a positive reputation.
You can download an owners manual for any of your F/L/M vehicles >>here<<
Old 01-24-2010, 02:00 PM
jennkent5454 jennkent5454 is offline
jennkent5454 is starting off with a positive reputation.
Old 10-08-2013, 07:40 PM
Old School Mechanic Old School Mechanic is offline
Old School Mechanic is starting off with a positive reputation.
Power Window Relay/Fuse
I just figured out that the fuse for the power window relay is the same fuse as the interior light. #14, 15 amp fuse in the fuse panel inside the cab.
Old 10-08-2013, 08:24 PM
Bluegrass 7 Bluegrass 7 is online now
Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.Bluegrass 7 has a good reputation on FTE.
73,707 views on this thread has to be a record of some sort for looing at fuse assignments.
Look on the under side of the cover.
GOOD LUCK.
Old 02-02-2014, 07:14 PM
mewesguitars mewesguitars is offline
mewesguitars is starting off with a positive reputation.
99 F150 horn & light issues
I just bought a 99 F150 and the horn doesn't work. Also the interior lights do not work with the doors open or on the dash switch. I don't have a manual and need the details on the fuse panel. If anyone has this info I would appreciate your help.
Old 02-03-2014, 07:00 AM
projectSHO89 projectSHO89 is online now
projectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant futureprojectSHO89 has a brilliant future
Quote:
Sigh....
See signature.
Old 04-18-2014, 06:51 PM
Jquinlan Jquinlan is offline
Jquinlan is starting off with a positive reputation.
A/c blowing hot
I want to change the fuse out to see if that is the problem before I do anything else. However not sure which fuse is the a/c. I have the diagram, but don't see any reference. The fuse box and temp blend door were replaced last year. Any suggestions.
Old 05-24-2015, 06:57 PM
Diagnostechs Diagnostechs is offline
Diagnostechs is starting off with a positive reputation.
Fuse identifiers
GOOD LUCK.
Ford stopped imprinting fuse locations and assignments on box covers before 1998, and if you do not have the owner's manual, you have to buy a shop manual or find it on the internet.
Old 05-25-2015, 01:12 PM
The fuse numbers are on the under side of the engine bay fuse box cover.
The cover is removable so you can see them better.
You do have to know what number fuse your after per the owner manual.
Not every truck 'build' has the same fuse assignments.
Good luck.
Old 11-26-2016, 11:51 AM
nickgonzo88 nickgonzo88 is offline
nickgonzo88 is starting off with a positive reputation.
That blown fuse will terminate power to most the interior lights and the power windows among other things. Relay/fuse 110 the "ACC Delay Relay" was blown in my truck not to long ago. With this relay/fuse blown my driver and passenger side power windows wouldn't work at all. This relay/fuse 110 is under the hood.
Before the relay/fuse blew, my drivers side window wouldn't go up. I bought a $19 switch for the power windows only on Amazon and it solved my problem when I replaced it. easy fix.
1966 Ford F100 Cab for Sale chorten1 Ford Truck Parts for Sale 1 03-19-2016 06:16 AM
Warning don't buy from Performance Machine In TN coolfeet 6.0L Power Stroke Diesel 54 10-27-2015 08:45 PM
Factory Shop Manuals for 1995 richard1586 All Other Items for Sale 2 07-16-2015 03:55 PM
Engine swap 1984 Todd Wenke 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 01-03-2015 07:44 AM
Tags
1992, 2001, 2006, box, diagram, digrame, f150, f250, ford, fuse, fusebox, manual, owners, panel, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
