Chevy engine swap?????? - Ford Truck Enthusiasts Forums
Old 09-05-1999, 01:26 PM
ga1998 ga1998 is offline
ga1998 is starting off with a positive reputation.
Hello all, I have a rather odd question. My friends son has just got a Ford F150, 1979. He wants to put a 350 chevy engine and transmission into this body. I told him that I didn't know if it could be done to rebuild the Ford engine (6cyl) but he is going to college and has built this chevy engine and transmission for 4 years now, is on a very limited budget, and his grand dad gave him this Ford body. Is there anyone that makes a conversion kit or that has information that can help me to help this kid? He assures me that he will fly the blue oval on the grill
Thanks for all your help.
Gerald
Old 09-05-1999, 01:35 PM
sparky's Avatar
sparky sparky is offline
sparky is starting off with a positive reputation.
Aren't you worried about organ rejection?
Seriously it can be done but I am sure it will be a complex project. I know of one person who converted a 60's Ford Falcon to a Ch@v 350 setup. Good luck.
Old 09-05-1999, 01:43 PM
I know that getting the air/ps/and alt will be so much fun but he has time and loves to cut and weld...
Gerald
Old 09-05-1999, 06:28 PM
Fordman Fordman is offline
Fordman is starting off with a positive reputation.
This is going to be a very complex process. The frame rails are different widths if I remember correctly. The motormounts might for some odd reason match the holes in the frame but I doubt it. Im sure someone has done it because the 2 brands have been around too long for this swap not to happen. As the others said there will be quite a bit of fabrication and cutting. As for the tranny I dont know how different the mounts are between the 2. This sounds like a fun project but make sure he takes his time and doesnt screw everything up. Good luck
Fordman
Old 09-05-1999, 07:00 PM
jowilker's Avatar
jowilker jowilker is offline
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Man If you have a heart, or soul take this crap somewhere else. This is a Ford List. This sir, is a respectable place, that women and children can visit.
Old 09-06-1999, 01:09 AM
390fe 390fe is offline
390fe is starting off with a positive reputation.
It could work with a lot of cutting, welding, and fabrication. Might be worth it to try and talk him into selling the truck and buying a Ch*vy, scince he's put so much time and effort into the motor already. As far as any kind of "conversion kit", he's on his own!
Old 09-06-1999, 02:29 PM
chenders chenders is offline
chenders is starting off with a positive reputation.
I am totally against *******izing the ford, but I know that Chev 350 can be mounted all most anywhere with out too much welding. The ps and wiring as not going to be that difficult, the gm alt has the regulator built in.
Good luck on your project and in School.
The University of Michigan
"Go Blue"
Old 09-06-1999, 03:20 PM
jowilker's Avatar
But the truck will only run backards.
Old 09-06-1999, 06:08 PM
Pastmaster Pastmaster is offline
Pastmaster is starting off with a positive reputation.
Thats a good one-Jowilker
Old 09-06-1999, 11:16 PM
Gerald Ash
Guest
Posts: n/a
Ok gang, I went and purchased a ch#*y pickup and traded for the Ford. He is happy.
I am sorry if your women and children can't see the ford/chevy cross.
I now have a problem. The only engine/transmission I have is from a 1988 Ford 5.0 efi/ado auto. I know the link for a kit to shift the transmission. Can I put an aftermarket intake and carb on this engine without changing the roller cam? and expect preformance? Do I have to change the distrubtor and if so will the Duraspark for a 302 of that year work?
Any help will be appreciated.
Gerald Ash
Old 09-08-1999, 09:34 AM
Bruce Bruce is offline
Bruce is starting off with a positive reputation.
Gerald:
Good move. Let him play with his chevy. He's in college and still has many lessons to learn. I own 10 vehicles, 9 Fords plus my wife's Volvo (which is now a Ford because Ford bought Volvo).
When it comes to raw horsepower a carb is better than port EFI. The reason is quite simple: the longer the fuel has to vaporize the better combustion you will have, therefore the more HP you can make, everything else being equal.
The trade-off is that EFI usually runs a little smoother, gets better mileage and is easier to start, especially on those cold mornings.
Good Luck and have fun.
Bruce
Old 09-08-1999, 01:12 PM
jowilker's Avatar
Gerald, have you thought about an aftermarket computer to run the transmission and the EFI. I think that I have seen that discussed on Shadetree Machanic TNN sat. afternoon.
Trucking magazines would be a good place to look.
John
Old 10-22-1999, 10:20 AM
TomC TomC is offline
TomC is starting off with a positive reputation.
Old 10-29-1999, 12:44 AM
mike mike is offline
mike is starting off with a positive reputation.
hey, yeah you can put he carb and intake on the 5.0 I had a 88 stang and was going to do it but some ******* stole it. THe only thing is the distributor gear and drive shaft for the oil pump. there are two diffrent ones and you have to use the one for your roller cam. not a problem. check out some mustang message forums that is where i found out about it.
Old 08-19-2014, 02:02 PM
NoBowTiesHere NoBowTiesHere is offline
NoBowTiesHere is starting off with a positive reputation.
I see a large benefit in the swap tho, very large quantity of ch3vy's at your local pic a parts, but then again THATS ALSO SAYING SOMETHING!
Gerald geraldsamanie New Member Introductions 1 10-06-2016 12:57 PM
Finally got a 57 C600! bluesdefender New Member Introductions 1 09-14-2015 12:42 PM
A thread for your Chevy lovers turned Ford stories radmacks Ford vs The Competition 15 05-21-2015 02:07 AM
Hell hath frozen over!! Pickupmanx2 1967 - 1972 F-100 & Larger F-Series Trucks 33 12-07-2014 04:16 AM
Fun little Ford story GM4WALLS 1973 - 1979 F-100 & Larger F-Series Trucks 8 08-20-2014 04:25 PM
Tags
400, 406, 62, carb, carbureted, chevy, conversion, engine, f100, f100chevyengine, ford, intake, motor, put, swap, swap1966
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
