Chevy engine swap??????
Old 09-05-1999, 12:26 PM
ga1998's Avatar
ga1998
ga1998 is offline
Hello all, I have a rather odd question. My friends son has just got a Ford F150, 1979. He wants to put a 350 chevy engine and transmission into this body. I told him that I didn't know if it could be done to rebuild the Ford engine (6cyl) but he is going to college and has built this chevy engine and transmission for 4 years now, is on a very limited budget, and his grand dad gave him this Ford body. Is there anyone that makes a conversion kit or that has information that can help me to help this kid? He assures me that he will fly the blue oval on the grill
Thanks for all your help.
Gerald
Old 09-05-1999, 12:35 PM
sparky's Avatar
sparky
sparky is offline
Aren't you worried about organ rejection?
Seriously it can be done but I am sure it will be a complex project. I know of one person who converted a 60's Ford Falcon to a Ch@v 350 setup. Good luck.
Old 09-05-1999, 12:43 PM
ga1998's Avatar
ga1998
ga1998 is offline
I know that getting the air/ps/and alt will be so much fun but he has time and loves to cut and weld...
Gerald
Old 09-05-1999, 05:28 PM
Fordman's Avatar
Fordman
Fordman is offline
This is going to be a very complex process. The frame rails are different widths if I remember correctly. The motormounts might for some odd reason match the holes in the frame but I doubt it. Im sure someone has done it because the 2 brands have been around too long for this swap not to happen. As the others said there will be quite a bit of fabrication and cutting. As for the tranny I dont know how different the mounts are between the 2. This sounds like a fun project but make sure he takes his time and doesnt screw everything up. Good luck
Fordman
Old 09-05-1999, 06:00 PM
jowilker's Avatar
jowilker
jowilker is offline
Man If you have a heart, or soul take this crap somewhere else. This is a Ford List. This sir, is a respectable place, that women and children can visit.
Old 09-06-1999, 12:09 AM
390fe's Avatar
390fe
390fe is offline
It could work with a lot of cutting, welding, and fabrication. Might be worth it to try and talk him into selling the truck and buying a Ch*vy, scince he's put so much time and effort into the motor already. As far as any kind of "conversion kit", he's on his own!
Old 09-06-1999, 01:29 PM
chenders's Avatar
chenders
chenders is offline
I am totally against *******izing the ford, but I know that Chev 350 can be mounted all most anywhere with out too much welding. The ps and wiring as not going to be that difficult, the gm alt has the regulator built in.
Good luck on your project and in School.
The University of Michigan
"Go Blue"
Old 09-06-1999, 02:20 PM
jowilker's Avatar
jowilker
jowilker is offline
But the truck will only run backards.
Old 09-06-1999, 05:08 PM
Pastmaster's Avatar
Pastmaster
Pastmaster is offline
Thats a good one-Jowilker
Old 09-06-1999, 10:16 PM
Gerald Ash
Guest
Posts: n/a
Ok gang, I went and purchased a ch#*y pickup and traded for the Ford. He is happy.
I am sorry if your women and children can't see the ford/chevy cross.
I now have a problem. The only engine/transmission I have is from a 1988 Ford 5.0 efi/ado auto. I know the link for a kit to shift the transmission. Can I put an aftermarket intake and carb on this engine without changing the roller cam? and expect preformance? Do I have to change the distrubtor and if so will the Duraspark for a 302 of that year work?
Any help will be appreciated.
Gerald Ash
Old 09-08-1999, 08:34 AM
Bruce's Avatar
Bruce
Bruce is offline
Gerald:
Good move. Let him play with his chevy. He's in college and still has many lessons to learn. I own 10 vehicles, 9 Fords plus my wife's Volvo (which is now a Ford because Ford bought Volvo).
When it comes to raw horsepower a carb is better than port EFI. The reason is quite simple: the longer the fuel has to vaporize the better combustion you will have, therefore the more HP you can make, everything else being equal.
The trade-off is that EFI usually runs a little smoother, gets better mileage and is easier to start, especially on those cold mornings.
Good Luck and have fun.
Bruce
Old 09-08-1999, 12:12 PM
jowilker's Avatar
jowilker
jowilker is offline
Gerald, have you thought about an aftermarket computer to run the transmission and the EFI. I think that I have seen that discussed on Shadetree Machanic TNN sat. afternoon.
Trucking magazines would be a good place to look.
John
Old 10-22-1999, 09:20 AM
TomC's Avatar
TomC
TomC is offline
Old 10-28-1999, 11:44 PM
mike's Avatar
mike
mike is offline
hey, yeah you can put he carb and intake on the 5.0 I had a 88 stang and was going to do it but some ******* stole it. THe only thing is the distributor gear and drive shaft for the oil pump. there are two diffrent ones and you have to use the one for your roller cam. not a problem. check out some mustang message forums that is where i found out about it.
Old 08-19-2014, 01:02 PM
NoBowTiesHere's Avatar
NoBowTiesHere
NoBowTiesHere is offline
I see a large benefit in the swap tho, very large quantity of ch3vy's at your local pic a parts, but then again THATS ALSO SAYING SOMETHING!
Quick Reply: Chevy engine swap??????
