should I have a cast or steel distributor gear? - Ford Truck Enthusiasts Forums
Old 01-23-2010, 09:49 AM
gnwalker's Avatar
gnwalker gnwalker is offline
gnwalker is starting off with a positive reputation.
Went to Autozone for a new distributor for my '78 302,brought the old one with me, and when ordering nobody wanted to say for sure what type of gear it had, cast or steel. 3 guys thought steel and one said cast. Told them I had a summit cam and it was decided I most likely should have steel. So now I have a distributor with a steel gear and I'm ready to drop it in but now I'm having second thoughts about the gear. Is it a big deal if it should be a cast gear?
Old 01-23-2010, 11:52 AM
Conanski's Avatar
Conanski Conanski is offline
Conanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud ofConanski has much to be proud of
That motor will have a flat tappet cam in it that requires a cast distributor gear, steel gears are only used on roller cam motors.
Old 01-23-2010, 12:44 PM
gnwalker's Avatar
Returned the steel gear dist and ordered the cast one, thanks
ford 400 distributor gear??? tomwerm 1973 - 1979 F-100 & Larger F-Series Trucks 19 03-24-2015 01:13 PM
92 5.0 in a 1965 Ford F100 (distributor gear) Dbass1292 Engine Swaps 3 03-03-2015 03:31 PM
Distributor gear question 302 1979 300i6 1973 - 1979 F-100 & Larger F-Series Trucks 4 02-03-2014 02:15 AM
Bone stock 302 Cam gear, Cast iron, correct? reamer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 01-24-2014 07:45 PM
More Confusion Steel or Cast gear on Dizzy reamer 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 1 01-23-2014 04:26 AM
Tags
1990, 302, 351w, 50, block, cast, distributer, distributor, ford, gear, have, small, specs, steel, xe264hr
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
