Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1948 - 1956 F1, F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1948 - 1956 F1, F100 & Larger F-Series Trucks Discuss the Fat Fendered and Classic Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 01-22-2010, 11:04 PM
nordvik72's Avatar
nordvik72 nordvik72 is offline
Garage is empty, add now
nordvik72 is new and has a neutral reputation at this point.
Got my 56" flange to flange 9 inch rear end now i need axles.
Ive been looking around for some axles for my nine inch but not sure of what it came out of. its about 56 inches from flange to flange so it will finally fit in bettween my fenders. i would like to buy a OEM type axle nothing crazy. i read in the articles above you could use '77-'79 T-bird, Cougar, LTD II, Ranchero, and '73-up Torinos left side (driver's side) axle but where do they sell them besides the junk yard.
  #2 (permalink)
Old 01-23-2010, 12:52 AM
HD74's Avatar
HD74 HD74 is offline
HD74 is starting off with a positive reputation.
Quote:
Currie, Currie Enterprises - Custom Rearends, Jeep/Off-road Parts, Crate Rearends, 4x4 Rearends
__________________
1951 F-1 w/French Flathead V8
2001 Road Glide
2008 Bobber
1981 FLH
  #3 (permalink)
Old 01-23-2010, 07:19 AM
AXracer's Avatar
AXracer AXracer is online now
1956 Ford Panel
AXracer has a great reputation on FTE.AXracer has a great reputation on FTE.AXracer has a great reputation on FTE.AXracer has a great reputation on FTE.AXracer has a great reputation on FTE.AXracer has a great reputation on FTE.
Chuck Frank
Summit Racing - High Performance Car and Truck Parts l 800-230-3030 Ford direct fit rear axles, Alloy USA stronger than OEM < 100.00 each.
If the pumpkin is in the center of the axle (equal length axle shafts) it's likely out of a truck, unequal length likely out of a passenger car. There is plenty of ID info on the internet, you'll need to know if 28 or 31 spline, large or small bearing, bolt pattern desired. Even custom axles are not horribly expensive if you want a different bolt pattern or special length.
__________________
Passionate about autocross racing!
1956 F100 Panel "GRACIE"
2007 Solstice GXP racer, the "KRAZED KANARY"
Third place finish 2009 SCCA National Championships
  #4 (permalink)
Old 01-23-2010, 07:56 AM
GreatNorthWoods's Avatar
GreatNorthWoods GreatNorthWoods is offline
GreatNorthWoods has a very good reputation on FTE.GreatNorthWoods has a very good reputation on FTE.GreatNorthWoods has a very good reputation on FTE.GreatNorthWoods has a very good reputation on FTE.
Hopefully you have the original nine inch truck backing plates, brake assemblies, and axle retainer plates because you will need them to use with the passenger car axles...
__________________
Vern
1949 F-1
  #5 (permalink)
Old 01-23-2010, 11:20 AM
nordvik72's Avatar
Quote:
yeah i do i had another 9 inch but it was alittle to wide.
Tags
56, 9, axle, currie, curry, driveshaft, end, flange, flanges, ford, inch, junkyard, length, rear, unequal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
