What is your fuel filter of choice? NAPA? Carquest?
What is the popular fuel filter here for 7.3s? Immediately after buying my truck used I bought a Carquest 86518 filter, these are the separate element that fits beneath the fuel filter cap...see pic below:
However, I was never able to install it without it leaking massively around the cap. I have followed the instruction regarding the direction to seat the beveled gasket and still end up spewing diesel. I've since switched to the NAPA one piece cap and filter, with no leakage problem.
I tried installing the Carquest filter again this evening after doing some work on the rig. Spewed again. Is there a trick to these?
What are other people using? Thanks.
Thanks for the replies
It is most curious- okay I have not tried dipping the gasket prior to installing...I'll try that the next time I give this a whirl.
Racors would be my brand of choice if I could get them...they are all that I've used in marine diesels. Thanks for the feedback gents.
Racor/Motorcraft for me also. Make sure your putting the beveld seal up and tighten down tight. The first one I ever changed on mine was doing what yours did. I had to tighten it tight to make sure the filter seated down right in the bowl. Take a few cranks before it tight. I use 2 flat screw drivers and cross them. After that one time of learning to put it in, I never had a problem since. No more leaks.
