Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2011 F100
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2011 F100 Discussing the much rumored mid-sized 2011 F100
  #1 (permalink)
Old 01-22-2010, 03:18 PM
westasheville250 westasheville250 is offline
Garage is empty, add now
westasheville250 is starting off with a positive reputation.
oil use
I have a 01 7.3l with 95000 mile and it seems to be using about 2qt of oil between fill ups (about 400mile).
any suggestions?
  #2 (permalink)
Old 01-22-2010, 09:14 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
2006 Ford F-250
My Garage
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Welcome to FTE westashville.
You'll have much better luck getting an answer if you post this in the 99-03 7.3 section.
Click on this link to get there: 1999 - 2003 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums
__________________
'06 F250 6.0 / '94 F350 7.5
Regional Chapters Moderator
SoCal FTE
Join our Chapter *HERE*
9/21/54 - 9/25/09
  #3 (permalink)
Old 01-23-2010, 05:00 PM
63' f100 63' f100 is offline
63' f100 is starting off with a positive reputation.
I dont know about the leak, but keep it filled up. check it every day if you have to. one of my cars has a slow leak and i have to put a little in every 4 days or so to keep it filled up. the last thing you want to do is have an engine with not enough oil in it.
__________________
CHEVROLET- Clutch Hangs Every Valve Rattles Oil Leaks Every Time
FORD- For Off Road Duty
  #4 (permalink)
Old 01-24-2010, 04:14 PM
cavitation cavitation is offline
cavitation is gaining momentum as a positive member of FTE.
Any blue smoke out the tail pipe or small puddles in the driveway? That is really heavy usage. I use about a half quart in 3,000 miles.
  #5 (permalink)
Old 04-10-2011, 09:50 PM
mrbill1943 mrbill1943 is offline
2010 Ford F-150
mrbill1943 is starting off with a positive reputation.
Try using a high miliage oil, they have additivaties in them that help with that problem. Also Lucus oil additive it also works pretty good.
Tags
1999, ford, oil, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
