2000 f150 lift - Ford Truck Enthusiasts Forums
2000 f150 lift
Old 01-22-2010, 12:43 PM
mike1589 mike1589 is offline
mike1589 is starting off with a positive reputation.
2000 f150 lift
ok so i just bought another truck..a 2000 f150, and i plan on puttin a 6 inch lift and a 3 inch body lift on it, anyone got some pics? im also wonderin what size tires thatll fit, ive heard of people fittin 40s with that setup
Old 01-23-2010, 03:25 PM
highteckredneck's Avatar
highteckredneck highteckredneck is offline
highteckredneck is gaining momentum as a positive member of FTE.
here is mine, got a 6" fabtech lift with 35's. i am not sure about fittin 40" tires with just 9" of lift 6+3" body but i know for fact you can do 38's.
Old 01-23-2010, 03:33 PM
found this truck at farmboycustoms in florida. they make the kit for the solid axle swap i am fixing to attempt. it has 44" swampers with about 16" of lift.
Old 01-23-2010, 03:39 PM
my bad, i meant farm boy fabrications of florida.
Old 01-23-2010, 03:44 PM
fordf150farmer's Avatar
fordf150farmer fordf150farmer is offline
fordf150farmer is starting off with a positive reputation.
hey highteck, where did ya get those 4x4 stickers? mine are all cracked from age and id like to replace them with somethin different. thanks
Old 01-23-2010, 07:07 PM
i had them custom made from a place by my house. they cost me about 30 bucks for both of them but they are saved in their computer so amytime they come off or start to peel i can just go get some more. the ones i have are cut from a rebel flag but they can do any design you want.
Old 01-23-2010, 07:09 PM
here is a websight i was looking at before i got them made.
4x4 Decal, Ford Decals, Ford Emblem, Stickers, Graphics, Parts and Accessories
Old 01-23-2010, 07:14 PM
hey thanks. i wasnt sure if you had them done or just bought them on line. i got a guy by me that i can go to and he is supposed to be good. i may have to check it out.
Old 01-23-2010, 07:19 PM
oh yea, its always great to have a little peice of somthing on your truck that nobody else has, you know as in custom accessory, lol. good luck
Old 01-24-2010, 07:55 PM
highteck, i like how your truck sits. i wasnt sure if the 6 inch lift would make a big difference but it actually does, which is good to know cuz i wont be doing all 9 inches at one time, i ll have to work my way up to it
Old 01-24-2010, 11:03 PM
Quote:
thanks mike, do you know whick your lift your gona get first? 6" does make alot of difference from a stock truck. i pulled beside one the other day and took a pic so you could see the hieght difference between them but i havent posted the pic yet.
Old 01-25-2010, 10:25 AM
ya id like to see that, and ill probably go with the 6 first and get the most expensive part out of the way.. how much is the rear lifted on yours? i looked at a few kits that only lifted the back 3.5, but i found one i think its BDS that lifts the rear 5.5 inches, its more expensive but id rather have the extra 2 inches in the back
Old 01-25-2010, 07:12 PM
the lift that i bought came with lift blocks for the rear. i just had to unbolt the u-bolts, add the blocks and bolt it back down. everything was included in the lift. i paid about 2,000 bucks for it. are you going to install it?
Old 01-25-2010, 07:14 PM
Quote:
wait i see what your sayin, the blocks are about 4.5" but the truck sits pretty level. i didnt crank my torsion bars or anything either.
Old 01-25-2010, 08:14 PM
86moneypit 86moneypit is offline
86moneypit is starting off with a positive reputation.
I bought the same lift for my truck from BDS, but i went with the full boat and got the skid plate and the new rear leaf springs. I was happy with the whole package, and now that the leaf springs have beded in the truck is pretty level now. If you call a physical dealer for BDS u will get a better deal than on the web.
Lifts Da boyz 1973 - 1979 F-100 & Larger F-Series Trucks 4 01-12-2015 08:52 AM
79' F150 4in lift, radius arm questions doug79 1973 - 1979 F-100 & Larger F-Series Trucks 7 07-07-2013 05:46 PM
1976 f150 lift White76 1973 - 1979 F-100 & Larger F-Series Trucks 3 11-06-2011 08:03 PM
Spindles, need to get rid of lift kit. kdokey 1997 - 2003 F150 11 08-05-2010 01:10 PM
Lift? topo4u2 Brakes, Steering, Suspension, Tires, & Wheels 6 05-17-2002 04:15 PM
Tags
04, 1997, 1999, 2002, 35s, 6, 6in, body, f150, ford, headers, installing, lift, shorty, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
