Replacing throwout bearing in a 4 cyl... - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 01-22-2010, 09:35 AM
staysbroken staysbroken is offline
staysbroken is starting off with a positive reputation.
Hey guys, I'm about to finally tackle the whining throwout bearing in my 97 Ranger. Got a couple questions before I get started tomorrow...
Is this something I need to have a service manual on hand for? I replaced the clutch (more than once ) in the Mustang I had as a teenager several years ago, but that was a cable clutch and this is hydraulic. Is there anything I won't be able to figure out on my own fairly easily? I won't be anywhere near an internet connection to Google information or search FTE if/when I need it.
Since I'm going to be draining the transmission fluid anyway (ATF, correct?) when I drop the tranny, would it be worth it to go ahead and fill it back up with synthetic? How much fluid does it take? It doesn't grind at all now, but it is a little tough shifting at first when it's cold out. It's got 135k on it now, and I plan on putting at least another 100k on it...
Thanks!
Old 01-22-2010, 01:18 PM
powersmoked's Avatar
powersmoked powersmoked is offline
powersmoked is gaining momentum as a positive member of FTE.
Thanks!
I will give you my suggestions. I am sure you will get a lot of opioions on this thread. The slave cylinders on these truck are a weak point. I would suggest replacing the slave cylinder. I have heard raybestos are pretty good. I am not positive but i believe the release bearings comes with most slaves. You might also want to consider replacing the clutch and pressure plate while the tranny is out. the originals are LUK they are pretty good clutchs . Finally while you are doing all the work why not just remove and replace the the pilot bearing....... from what i have read Mercon seems to be the suggested fluid. also replace the plugs at the top by the shifter.......
you should get the tool that helps remove the hydralic line from the slave.
Old 01-22-2010, 02:49 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
Very, very good advice from powersmoked.
I would suggest that you go to autozone.com and register (free) with the Repair Section where you will get access to alldata and a decent blow by blow description of what`s involved. May even be able to print it out for reference.
Good luck.
Old 01-11-2011, 06:37 PM
Mudhorse Mudhorse is offline
Mudhorse is starting off with a positive reputation.
Hey all - I'm ready to replace the throw out bearing / clutch release bearing and my manual is terrible. It doesn't really tell me how to get the dang thing off. Can someone lend a hand here? Thanks.
Old 01-11-2011, 06:51 PM
danielwd danielwd is offline
danielwd is starting off with a positive reputation.
Quote:
The throwout bearing comes preassembled as part of the new slave cylinder. You need to replace the complete unit. I think the new slave cylinder/throw out bearing unit cost me about $50 from autozone.
I would hope that you are going to go ahead and change out your whole clutch unit while your at it. If you have the tranny off, you'd be crazy not to. Also, make sure to have the flywheel resurfaced and replace the rear oil seal if at all possible. I would also replace the pilot bearing which was the worst part for me. I couldn't make me a tool good enough to get the dang thing out so I had to rent a puller from Autozone to get the job done. The puller even sucked as it would'nt fit into the pilot bearing so I had to cut out a couple of holes out of the pilot bearing to fit the puller in.
Old 01-11-2011, 08:03 PM
if you drop the tranny you at a minumum should change the slave along with the throwout bearing
+1......
Old 01-11-2011, 09:18 PM
Thanks for the posts guys. I'm under the Ford to replace the clutch plate, doing the throw out bearing while I'm there...
Since my post I got the bearing off by using a Google search. Unfortunately I couldn't find anything on Ford-Trucks.com right away.
Also Haines is a garbage manual so don't buy one if you are looking for a manual!!!
Danielwd - good looking out, thanks for the pointers on rental tools.
Powersmoked - you post a lot, I appreciate your help bud.
Old 01-11-2011, 09:40 PM
xxshine xxshine is offline
xxshine is starting off with a positive reputation.
Consider going with an aftermarket clutch like Centerforce. That clutch is 1/2 inch larger in diameter than stock, so more clutch is hitting flywheel.
Old 06-01-2014, 10:53 PM
TJ Stewart TJ Stewart is offline
TJ Stewart is starting off with a positive reputation.
Exactly how to diagnose if its the throw out bearing?
My 5 speed 97 ranger is making this grinding kind of noise when I am at a light in gear with the clutch in....it seems to go away if I put her in neutral and let the clutch out at the light......then I start off normally in 2nd gear and I am ok, but someone mentioned it might be my throw out bearing? Any other suggestions? There isn't a lot of play in the clutch, so someone said my clutch is probably ok, what else could this be? I had the tranny fluid changed. thanks guys, tami
Old 06-02-2014, 06:37 AM
Dan Robertson Dan Robertson is offline
Dan Robertson is starting off with a positive reputation.
I also replaced the pilot bearing in the crankshaft as that was what failed in my 98 Ranger. The bearing piled up and caused the input shaft to bind. I could have borrowed the bearing puller from the local Car Quest Store but for what it cost ($50.00) I bought it instead.
HELP! Hydraulic clutch problem! TheMechanicalAnimal 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 34 12-07-2016 10:22 AM
Recommendations for a Quality Throwout Bearing? Inline66 1961 - 1966 F-100 & Larger F-Series Trucks 15 05-27-2016 01:41 PM
throwout bearing and slave cylinder HELP! patch2285 1987 - 1996 F150 & Larger F-Series Trucks 0 11-08-2014 12:22 PM
Clutch not disengaging TwoMuchMud Escape & Escape Hybrid 13 09-23-2011 02:05 PM
Could Bad Throw-Out Bearing Cause Clutch Chatter? matt2491 1961 - 1966 F-100 & Larger F-Series Trucks 3 06-21-2008 08:55 AM
Tags
2004, 97, bearing, bearings, clucth, ford, hydraulic, luk, mazda, ranger, remove, replace, throw, throwout, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
