Vaccum Pump Pressure? - Page 2 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
Old 01-22-2010, 08:38 AM
Cuda_jim's Avatar
Cuda_jim Cuda_jim is offline
Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.Cuda_jim has a great reputation on FTE.
Quote:
Originally Posted by 91dirtydiesel View Post
id take my brakes being soft all day compared to having to pull the brake pedal back up with my foot like i do. any one know how to fix that?
My guess is the master cylinder.......the return spring is broke or it's just hanging-up internally. Take a look for binding in the pedal pivot too.
Old 01-22-2010, 05:39 PM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
18 in hg vacuum or more more is spec for the vauum pump. If you have a low pedal then vacuum is NOT your problem. Your rear brakes could be out of adjustment, ABS valve is bad, Master cylinder is bad, or you have a leak. Most common cause is rear brakes out of adjustment. For a test use a pair of vise grips a adjust them so they just clamp the rear brake hose off then hit your brakes. If its still soft then get two more sets of vise grips and clamp the front hose too. If its still soft then you either have a Master cylinder or ABS valve issue.
Old 01-22-2010, 06:28 PM
wheelie31's Avatar
wheelie31 wheelie31 is offline
wheelie31 is starting off with a positive reputation.
is there a way to just test the ABS actuator? since the brakes are fine and the master cylinder is withen 1 year old.
Old 01-22-2010, 06:39 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Quote:
Originally Posted by wheelie31 View Post
my brakes work there just squishy and pedel goes done pretty far, I bleed them a couple times, I have worst luck with the brake system i put all new lines on new brake cylinders brake booster and master cylinder all at once last year, and still have problems,
You still have air in the system .. maybe bench bleed the master cyl first
Old 01-22-2010, 06:40 PM
I have bad luck with brakes too. My current problem is that my pedal wont return without me pulling it back up with my foot. I hate brakes lol
You need a new master cylinder ....
Old 01-22-2010, 07:01 PM
paddler paddler is offline
paddler is starting off with a positive reputation.
Bad Vacuum = HARD brakes
If the vacuum system is bad, you get no power assist, and have to push the hydraulic fluid with only your strength. Good hydraulics and bad vacuum will feel VERY hard and pedal will move very little. Do a double-leg-press on the pedal to get stopped (eventually), but you won't bottom out the pedal.
Really soft pedal suggests good vacuum (pump, lines, booster) but squishy hydraulics.
Sounds like your problem isn't vacuum.
Old 01-22-2010, 11:33 PM
tjbeggs's Avatar
Have you adjusted the rear brakes up correctly? Take my advice by clamping brake lines and report back. It is testing and will keep you from spending money that won't fix your problem. Trust me I have been down this road about 100 times....2 times this week.
Old 09-29-2013, 11:44 PM
Michael96 Michael96 is offline
Michael96 is starting off with a positive reputation.
Is that inches of mercury?
Missing Vaccum diagram stinger57 Nevada Chapter 1 12-20-2016 09:26 AM
2008 E350 6.0L Sat13579 6.0L Power Stroke Diesel 1 08-02-2016 10:11 PM
4.9L ported vaccume not working F100XL300I6 New Member Introductions 3 04-26-2014 08:53 AM
Fuel pump blowing not sucking! Buyerz 1973 - 1979 F-100 & Larger F-Series Trucks 11 03-23-2014 11:57 AM
Vacuum / brake system problem smuzz 1999 to 2016 Super Duty 9 04-06-2010 07:53 AM
Tags
1991, 450, 73, 73l, 95, 97, booster, brake, check, f350, ford, idi, pump, purpose, replace, testing, vacuum
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
