Bronco is back in the stable.
I seen ya smile, yes my pal got his Mustang back and it is now sporting a new aftermarket air induction hood with some ghost flames, I haven't seen it yet so I'll have to reserve judgment until friday when I see it.
Sure is nice to have the Bronco back, went for a short trip to the Crappy tire store for a TFI coil plug pigtail then back home.
Rick.
You're killing me Frank
It works ok when the head lights are off but when the head lights are on it's intermittent in it's flashing and very dull in the signal brightness.
So in the spirit of your coil wire it was a problem, we checked and cleaned all the ground wires including the ones behind the dash changed flashers and light switches couldn't get it to work.
We finally found the problem was the signal socket, cut the old one off and soldiered in a new one, problem solved.
Not the only Bronco related work we did yesterday.
Rick.
