Glycerin Disposal
Old 01-21-2010, 07:40 PM
Tom D's Avatar
Tom D
Tom D is offline
Glycerin Disposal
I have 50 gallons of glycerin I need to get rid of. If I lived on a farm or ranch, it would be easy. I live in the city so that's a problem. I stopped by the sewage treatment plant today and they were no help. Since they are not sure what it is they said "no". I know, I could probably dump a little at a time down the drain and no one would know but I don't want to take the chance of getting caught. Anyone have any suggestions? The methanol has been removed from it.
Thanks Tom
Old 01-21-2010, 07:58 PM
fabmandelux's Avatar
fabmandelux
fabmandelux is offline
If I remember right Tom you're using KOH? If you are, you've got some great fertilizer in that drum! I've mixed it 50-50 with hot water and sprayed it on my alfalfa fields with great results. If you know any gardeners that use a compost pile give it to them. It promotes bacteria growth and cuts the time required for composting. You can also use it to make a very good liquid soap!
Old 01-22-2010, 10:31 AM
TurnerBioDiesel's Avatar
TurnerBioDiesel
TurnerBioDiesel is offline
if you are in WI we will take it. If its from koh you could also make some nice liquid soap and degreaser.
Old 01-23-2010, 01:45 PM
Tom D's Avatar
Tom D
Tom D is offline
Thanks for the suggestions. I DO use KOH ,
Tom
Old 01-28-2010, 11:15 AM
Knotwild's Avatar
Knotwild
Knotwild is offline
I use a good bit in a compost pile, but we have 6 horses, so that part is easy. You do have to dilute it with water to get it to really soak in.
I have also disposed of it by using it to burn brush piles. I throw it on a really hot fire and get away so I do not inhale the smoke.
If you contact anyone in the concrete business, they can use it to coat their forms so the concrete won't stick.
If you pm me I have the soap making fomula. KOH makes a liquid soap and I bet you could sell most of it (or give it away if so inclined) to mechanics. I do know that the pure demethed glycerin makes a fantastic hand cleaner. If you haven't tried it, you should.
Old 02-10-2010, 01:01 PM
JAFO1's Avatar
JAFO1
JAFO1 is offline
I'd like to find someone around N Ft Worth with a little extra glycerin to give away.
Knotwild
Bio-diesel, Propane & Alternative Diesel Engine Fuels
05-14-2009 03:03 AM
Fett Affen
05-04-2009 02:01 PM
Catsailor
13
03-30-2008 10:10 AM
bobrl13
20
03-12-2008 08:35 PM
JOAT101
05-27-2006 08:51 PM
Quick Reply: Glycerin Disposal
