Squealing is driving me crazy!!
I have a 1995 F150 XLT with the 5.0L 302 and there is a squealing coming from the engine that sounds just like a belt squeal. I replaced the belt tensioner and the belt and it still squeals. It just started this winter and usually only does it when the truck warms up. Any ideas??
you need to get the most expensive belt you can find the one with the rib things on the back..also one time my smog pump seized and was squealing so bad i was going 100 the whole way home on the freeway cuz i just put a new smog pump that was siezing (spinning slower then the belt but still spinning?) and causing a squeal
I'd check out all the bearings in your accessories if you have taken care of the belt. If it only does it when it's warming up, that could mean that a bearing somewhere needs to warm up and, through thermal expansion of the bearing material, it stops squealing when the worn bearing expands just enough and the slop becomes less. This might be a blessing in disguise, indicating a bigger problem before it happens!
as some of the other members mentioned, check out the bearings by trying to listen to each one individually somehow.
Good luck!
Good luck!
CHECK PULLEY ALIGNMENT
I have a '92 F150 4.9l....When I replaced the power steering pump pulley i did not press it on quite far enough and the belt would squeal like a pig in heat. This was only a 16th of an inch or so out of alignment. The squeal was coming from the tensioner pulley. I pressed the pulley on a bit further and the squeal was gone for good. I tried belt dressing first but that only made a big a$$ mess.
I like Goodyear Gatorback and Dayco Polycog belts.
A mechanices stethoscope may be your best friend for this. I have this one and its not expensive.
Stay away from belt dressings.
Automotive Stethoscope - JCWhitney
Well I went to the local salvage yard on the weekend and found me a smog pump, and changed it out, but the squealing is still there. Well even though the pump wasn't the squealer, it was rattling inside pretty good. Guess I will work my way up through the idlers and save the alternator for last. Just to try to save a few bucks, is it possible just to change out the bearing in an idler? Has anyone tried it?
