83 F100 3-speed MT Column Collar Part No - Ford Truck Enthusiasts Forums
Old 01-21-2010, 04:02 PM
johnsscott2's Avatar
johnsscott2 johnsscott2 is offline
johnsscott2 is starting off with a positive reputation.
Newbie here.
Have an 83 F100 I6 with a three-on-the-tree manual transmission. Column collar has sheered off. Having trouble finding the part - have gone to LMC Truck, NPD, and local salvage yards to no avail.
Expanding my search to Ebay and such, am finding some for other years (e.g. 78-79) but not sure which ones will work with the 83. Can anyone point me to a source for the original correct part number for the 3-speed column shift version of the column collar on the 83?
TIA - John
Old 01-22-2010, 04:16 PM
1986F150six 1986F150six is offline
1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold1986F150six is a splendid one to behold
NumberDummy can provide the information, if anyone can. Perhaps he is online?
Old 01-24-2010, 12:18 AM
PaulzF150 PaulzF150 is offline
PaulzF150 is starting off with a positive reputation.
Are you sure that you need a new shift collar? I had a '83 F100 with the 3 on the tree like you have. I had the same problem. I drove my truck down the road in first gear over to the Ford Dealer to get it fixed. Big mistake! They charged me $250.00 to replace the shift collar and the bushing. That was back in 1991. About 100K miles later it happened again. I found a local mechanic who charged me $75.00. He replaced the bushing which back then cost $5.00. He explained that there is a plastic bushing that wears out, making shifting very sloppy, then it eventually breaks. I hope you can still find the bushing. If you have trouble, let me know. A friend of mine bought that truck off me back in '99. He still has it. Chances are that it probably has happened again, I can find out for you if he was able to find the part and where. Good luck .
Old 01-24-2010, 12:26 AM
Sounds like I need to stock up on a few bushings too, to have them around as they wear out - I appreciate the advice. I can, however, see the where the collar has sheared off - its a mangled mess. Definitely have to replace that, but thus far haven't been able to find one...
Old 01-24-2010, 12:35 AM
I just emailed this information to that friend of mine. I'll let you know what I find out. Another thing with those trucks is that clutch rod that attaches to the clutch pedal and goes through the floor to the shift linkage. The ends on those wear out. Depending on how long you intend on keeping the truck, you may want to see about having a spare clutch rod assembly around.
Old 01-24-2010, 03:09 AM
86bigred's Avatar
86bigred 86bigred is offline
86bigred is gaining momentum as a positive member of FTE.
you could put a floor shifter in as an option.b&m and mister gasket make them.one of them is better than the other can't remember.some one will chime in on which on is better.
Old 01-24-2010, 11:44 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by johnsscott2 View Post
Have an 83 F100 I6 with a three-on-the-tree manual transmission. Column collar has sheered off. Can anyone point me to a source for the original correct part number for the 3-speed column shift version of the column collar on the 83?
Welcome to FTE
When you say the collar has sheard off, what does that mean?
The collar snaps inside the column where it connects to the shift tube, causing the shift lever to hang limp.
EOTZ7228D .. Shift Collar / Use with 3 speed M/T / Does not come with the shift lever / Obsolete
Fits: 1980/87 F100/150 & Econoline / Sorry, no Ford Dealer or obsolete parts vendor has any.
Old 01-24-2010, 02:34 PM
I haven't disassembled it yet, so the pic below is looking down into the still assembled column between the collar and the part above:
To help clarify, here's the part off of a '79, and I've circled the place where it has sheared off...
thanks much for your help.
John
Old 01-24-2010, 05:26 PM
..Exactly.
Old 01-30-2010, 04:15 AM
guitarjay76 guitarjay76 is offline
guitarjay76 is starting off with a positive reputation.
guess I must be one of the chosen lucky few. mine's got 99000 original miles and the 3 on the tree still slides right in place, unlike most mickey - moused messes I've come across in the past. I'm tellin' ya though... I can't wait to put a 5 speed in it and get away from that column shift. Whoever thought that up really needs a swift kick in the you know what! bad design all the way...
Old 06-02-2010, 05:10 AM
ragpicker ragpicker is offline
ragpicker is starting off with a positive reputation.
Thumbs up 3 Speed
Did u ever go to 5 speedis your three on the tree column or collar for sale
frankcampbell40@yahoo.com
Ps i broke mine off need really bad
tnks
frk
Old 06-02-2010, 05:24 AM
Three on tree Shifter broke off
Hello
Just read thru some of the old post an yours stands out.
I to have a problem finding the column or the collar can you give some help to and old man who has forgotten more than he now knows .I really do not want to go to three by the knee
tnks frk
PS
al lhelp aaapreacated
Old 06-02-2010, 08:34 AM
Ragpicker -
I did get mine fixed. After a couple of weeks of searching and being told no one had the collar, I looked at junkyards for the whole steering column... wasn't finding those anywhere close to me either. Then just happened to get hooked up with a a friend of a friend who knew a guy (yep, one of those stories) at a dealer up in Illinois or Iowa or someplace who said they had one sitting on a shelf at the dealership. Got them to ship it to me.
There are still a few of these out there, its just a matter of getting lucky enough to find one of the few...
Best of luck in your search!
Old 06-02-2010, 08:55 AM
Ragpicker -
EOTZ7228D .. Shift Collar-Use with 3 Speed Manual Transmission: Fits: 1980/87 F100/150 & Econoline / Obsolete
No Ford Dealer has any listed on the in-house Ford Dealer Parts Locator System that every US and Latin American dealer uses.
I suggest you vist your local dealer, have them run this part number, see how many are available.
You will soon discover that no one has any.
When no source shows any, and this includes all the obsolete parts vendors, as I also ran the part number on their website, there's nothing else I can do.
Old 06-02-2010, 10:07 AM
83 F100 3-speed MT Column Frank
Thank you very much for the comeback .I am not syre what to do @ this time
tnls
frk
Question for NumberDummy, steering column collar asmith6 1961 - 1966 F-100 & Larger F-Series Trucks 2 06-19-2016 06:12 PM
help looking for a 3spd column shift collar minnesota-clint 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 3 10-20-2014 12:00 PM
column collar broke Brandon Webb 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 06-14-2014 11:13 PM
HELP !! Steering Column Problem biggkahuna83 1973 - 1979 F-100 & Larger F-Series Trucks 2 10-01-2012 11:57 PM
Part # for Manual 3 speed Shifter Column Collar SoCal74F100 1973 - 1979 F-100 & Larger F-Series Trucks 5 08-20-2012 06:47 PM
Tags
1980, 3spd, collar, colum, column, eotz7228d, f100, find, ford, manual, parts, shifter, speed, thre, tree, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
