Replacing Power Steering Fluid Reservoir
My power steering reservoir was leaking, I thought from the return hose. I went to replace that and the hose barb on the fiberglass reservoir went "snick." I now suspect that was where it was leaking.
My Haynes manual does not address replacing JUST the reservoir. Best I can figure is that I remove the bolt form the Pressure side, which appears to be the only thing holding the reservoir on the pump, and pull the broken reservoir off. Putting the new reservoir is simply sliding it on the pump (remembering to place o-rings where appropriate), and putting Pressure side bolt back in to hold it in place.
Am I in for any surprises once I start this project, or is it pretty strait forward?
Okay, so that was interesting. The reservoir I ordered from Advance was just a touch to small and cracked when I put it on. I took it back and just bought an OEM pump. At this point it was worth the extra $30 to get the truck up and running. The pump went on easy, everything looks good. Thanks again for the responses on this.
Now, Someone mentioned it another post, and I will confirm the tool rental policy at autozone is awesome. I went and put a $30 deposit on the pulley remover tool, came home, changed the pump, returned the tool and got my deposit back. Awesome policy.
JWA
05-06-2021 03:18 AM
bghnkinf250
55
11-12-2017 11:33 PM
Dank Hill
64
12-23-2015 11:20 PM
bout-time
13
03-18-2014 07:36 AM
