Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 01-21-2010, 11:51 AM
Matt In Detroit's Avatar
Matt In Detroit Matt In Detroit is offline
1993 Ford Bronco
Matt In Detroit is starting off with a positive reputation.
Climate contol hiss on Auto
I have a 2007 Exped EB. It has the electronic climate control. After the vehicle comes up to temp on Auto heat, and it is just maintaining the cabin temp, there is a noticeable hiss noise from the lower dash area. If you switch the airflow to the vents or the floor or defrost it goes away. So, only on AUTO, and when the cabin is warmed up and the climate control is on slow maintain temp mode. Anyone have an idea? sounds like a vaccuum hose just sucking air. Its quite noisy.
Thanks for any help.
  #2 (permalink)
Old 01-21-2010, 03:43 PM
berry1234's Avatar
berry1234 berry1234 is offline
Garage is empty, add now
berry1234 is gaining momentum as a positive member of FTE.
This may or may not be it. Might have a hose unconnected. Turn it on and get under there with a flash light.
TSB 08-9-8
05/12/08
WHISTLE NOISE FROM THE HEATER/AIR
CONDITIONING WHILE CHANGING TEMPERATURE
SETTING - BUILT ON OR BEFORE 12/4/2007
FORD:
2007-2008 Expedition
LINCOLN:
2007-2008 Navigator
ISSUE
Some 2007-2008 Expedition and Navigator vehicles built before 12/4/2007 may exhibit a whistle noise from the heater/air conditioning while changing temperature setting.
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
Confirm customer symptom by cycling the temperature door as follows:
Manual System:
1. Set blower motor speed to number 2.
2. Set mode to PNL/FLR mode (most noticeable). Whistle may be audible in Vent or DEF/FLR but to a lesser extent.
3. Set the temperature **** all the way to full hot.
4. Start backing off full hot incrementally while listening for whistles. Whistle should be audible when the **** position is roughly between 5/8 and 3/4 position.
Dual Air Temperature Control (DATC) System:
1. Manually set the blower motor speed to medium or medium high.
2. Manually set mode to PNL/FLR (most noticeable). May be audible in Vent and DEF/FLR.
3. Set the temperature set point to highest temperature 90 °F (32 °C).
4. Start reducing the temperature set point incrementally while listening for whistles. Since the blend door position is dictated by several inputs like in-car temp sensor, ambient temp sensor, and sun load sensor. The whistle can be anywhere in the range except full cold.
If the whistle noise is present during the conditions above, replace the evaporator assembly. If the noise is not present during these conditions, refer to workshop manual diagnostics.
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #3 (permalink)
Old 01-23-2010, 08:40 AM
eddiemoney eddiemoney is offline
eddiemoney is starting off with a positive reputation.
My 2010 does the same thing, sounds like a door or somehting isn't quite shut and air is just rushing by it.
  #4 (permalink)
Old 01-23-2010, 11:18 AM
berry1234's Avatar
I know if the dash vents are not almost fully open, you will get a whistle type noise from them.
__________________
Tags
2001, air, auto, automotive, climate, control, ford, heater, hiss, idle, lincoln, makes, navigator, noise, trucks, whistling
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
