Tail lights stay on
Old 01-21-2010, 10:48 AM
whitewood's Avatar
whitewood
whitewood is offline
Tail lights stay on
1994 F-150 the tail lights remain on -after the lights are turned off and the truck is turned off.I have replaced the brake switch- nada no change- checked all of the fuses- nope.At this time when I park I pull the fuse which does shut off the lights- and then put it back in when I start back up.
Old 01-21-2010, 12:36 PM
mike460's Avatar
mike460
mike460 is offline
So is it the tail lights or the brake lights? If it is just tail lights it could be that the switch or the connector to the switch is messed up allowing power to pass through it. On my 88 my headlight switch connection was so bad the headlights, tail lights, and front corner lights could all come on with NO FUSE. Yea that was fun - soldered in a new connector from Ford and fixed it. Good luck!
Old 01-21-2010, 01:12 PM
White 97 xlt's Avatar
White 97 xlt
White 97 xlt is offline
Yes, knowing WHAT lights stay on would be a big help, tail lights and brake lights are completely seperate..
One thing I can think of is: If you have a trailer connector with aux power (battery charge to camper) to the trailer it could be a wiring problem where it ties into the truck or in the connector..
You would be amazed at the problems a sloppy wiring job can cause...
Old 01-22-2010, 07:42 PM
*2fords*'s Avatar
*2fords*
*2fords* is offline
Sounds like you're talking about your brake lights staying on. I just went through that myself. Turned out to be melted wires underneath the dash, and had to replace the turn signal/wiper switch.
dennis112
1997-2006 Expedition & Navigator
12-04-2021 01:00 AM
jbullfrog
1999 to 2016 Super Duty
17
01-12-2018 10:10 AM
Wally Williams
02-03-2017 08:52 PM
6.9idiatsturbo
18
08-15-2016 05:54 PM
V10man
03-16-2014 06:07 PM
Quick Reply: Tail lights stay on
