lifter cover
Old 01-21-2010, 09:20 AM
tomde2's Avatar
tomde2
tomde2 is offline
lifter cover
hi all,
i got a 4.9l that I'm replacing the gasket on the lifter cover(not sure of its official name). i noticed how flimsy this cover is and probably is part of the reason it leaks. my question is does anyone know of any company that sells an aftermarket cover that might be a little more solid?
thanks
Old 01-21-2010, 09:57 AM
coolguy1419's Avatar
coolguy1419
coolguy1419 is offline
Ive change this on my truck. It's a Push rod cover. Mine was sorta flimsy to but the gasket is a pretty thick rubber gasket and when u tighten it down it seal pretty good. Didn't have any problem with mine once I changed it. When u change it put a Little bit of gasket sealer or something on the backside of the gasket to the cover otherwise it's a pain and wants to fall out of the grooves when you put it back on.
Old 01-21-2010, 10:01 AM
tomde2's Avatar
tomde2
tomde2 is offline
ok - i'll try that thanks
Old 01-21-2010, 10:26 AM
kotzy's Avatar
kotzy
kotzy is offline
I used to glue the gaskets in with 3M Trim cement. The only problem is they are a mess to get out if you have to change them at some later date. I often thought about fabricating a cover from some 3/16 stock steel or aluminum. You would have to get the groove for the gasket cut in with a milling machine. The other option would be to get the OE straight and take it to a foundry and use it as the pattern to pour on in aluminum. A well versed moulder could gain the extra thickness by the way he sets it in the sand. Shrinkage in aluminum is not that great that it should present a problem in the lenght of the piece. kotzy
Old 01-21-2010, 12:53 PM
Harte3's Avatar
Harte3
Harte3 is offline
Some swear by the use of Indian Head Gasket Shellac sealer. It is a Permatex product.
Old 01-22-2010, 10:35 PM
Ranger GT2's Avatar
Ranger GT2
Ranger GT2 is offline
When I replaced mine I had to make sure the cover was flat. Some times is can get bent some and then it will leak. I used Permatex high tack gasket sealant to hold the rubber gasket to the cover. It was a breeze to put in then. I don't think you can put one on without using something to hold it in place.
Old 01-23-2010, 12:44 AM
9.ford.5's Avatar
9.ford.5
9.ford.5 is offline
dont over torque them bolts...look it up but the torque spec is somewhere round 24 or 27 INCH pounds not foot pounds
if you over torque the bolts it twists the panel then it doesnt seal...thats why you need to make sure its straight when it goes in cuz the torque is so small if its twisted in any way it wont seal either
they are pretty picky and can be a PITA for something so simple...lemme tell you they are 100x easier on carbd engines then EFI haha
Old 01-23-2010, 09:47 AM
jem44357's Avatar
jem44357
jem44357 is offline
Originally Posted by tomde2
hi all,
thanks
I have searched and not found one. I would really like an aluminum one.
Jim
Old 01-24-2010, 08:23 PM
NavyMIDN08's Avatar
NavyMIDN08
NavyMIDN08 is offline
a nice trick finned aluminum cover would really dress up the side of the engine. of course, its already nearly impossible to get ahold of the nice, finned aluminum valve covers. when you put the cover back on, ensure that the edges around the bolt holes on the cover aren't dimpled down. if they are, gently work them back into shape. a body hammer and anvil (or bench vise) work well for this.
Old 01-24-2010, 11:04 PM
Black_Stallion's Avatar
Black_Stallion
Black_Stallion is offline
I had the same Problem. I ordered a valve cover from LMC truck. A chrome one and i haven't had a problem yet. It does get dirty tho, but if your not a clean freak like i am it wont matter haha.
Old 01-25-2010, 12:12 PM
F-250 restorer's Avatar
F-250 restorer
F-250 restorer is offline
A nice finned aluminum lifter cover would be a sharp addition to any engine. I wanted a bit more pazazz to my 300, so I took my lifter cover in to a shop and had it chromed for $70.
I don't care for the tinny chrome v. covers, but I like the shiny look, so I bought a used Clifford cover on ebay, stripped the paint off, and had it polished.
<a href="http://s659.photobucket.com/albums/uu316/bobbyrogue/?action=view&current=P1010287.jpg" target="_blank"><img src="http://i659.photobucket.com/albums/uu316/bobbyrogue/P1010287.jpg" border="0" alt="Photobucket"></a>
<a href="http://s659.photobucket.com/albums/uu316/bobbyrogue/?action=view&current=P1010212.jpg" target="_blank"><img src="http://i659.photobucket.com/albums/uu316/bobbyrogue/P1010212.jpg" border="0" alt="lots of room"></a>
85lebaront2
03-12-2014 05:51 PM
79Ford250MR
02-19-2014 10:13 PM
e-3507.3
08-25-2010 10:37 PM
asder
Modular V10 (6.8l)
27
12-09-2008 03:47 PM
cbfomoco
09-27-2005 07:22 AM
Quick Reply: lifter cover
