I need rear quarter panels
A quarter panel is the entire outer/inner side of the bed and includes the inner wheel well and the quarter panel extension, which is prolly what you do want...as this is where the taillamps fit.
The extensions were also available separately and were welded onto the quarter panels.
The following fit: 1964/66 F100/250 2WD Stylesides and 1966 F100 4WD Stylesides.
C4TZ99280A58A .. Right Quarter Panel Extension / Obsolete
No Ford Dealer or obsolete parts vendor has any.
C4TZ99280A59A .. Left Quarter Panel Extension / Obsolete
GREEN SALES CO. in Cincinnati OH has ONE = 800-543-4959.
No Ford Dealer, no other obsolete parts vendor has any.
I do not know if these extensions have been reproduced.
Well since there is no repro pieces availabe how about some from a bronco. I found some on bronco graveyard but im not sure if they are the same dimensions since the bronco looks smaller the the F100.
heres a link
Tail light section, left
heres a link
I do not believe you want quarter panels which are also known as bed side panels.
The following fit: 1964/66 F100/250 2WD Stylesides and 1966 F100 4WD Stylesides EDIT: And 1966/68 & 1969 Bronco's before serial number E24,001
What the difference is between early and late 1969 Bronco extensions, I dunno.
The 1969 Bronco from serial number E24,001 and 1970/77 Bronco extension part numbers are: C9TZ97280A58A & C9TZ97280A59A.
Bronco Graveyard lists 1966/77 as the same, but the 1965/72 Ford Passenger Car Parts Catalog does not, and the original 1964 part numbers were never updated.
The early ends have no side marker light. Later ones do. Just the same as the style side bed ends for trucks. I guess there needs to be slight modification to accommodate the light for later years.
Great on the cross reference Bill. There is quite a bit that interchanges. The most notable being the speedometer with the additional oil and amp gauge built in to the round cluster.
Also one can use the bronco rear lower quarter repair panels to fix the wheel arch for aft of wheel damage.
Garbz
Garbz
the graveyard pieces SUCK!!!!!I can not stress how much their parts blow.The extensions dont even have the tabs for tail lights.we have a bronco we are doing for a customer and he bought the parts previously and we have learned now that bronco hut is MUCH better quality...
sorry for the rant just frustrating.
mrduke41
1978 - 1996 Big Bronco
01-03-2013 10:43 AM
mikeg216
11-22-2011 07:56 AM
