Need some help about fuel guage
Im stumped. I was putting my leds in and had the switch to the run position. When i was finished i went back to turn the key off and i have no gas. When I started i had 1/4, when i was done it registered "E". I called the dealer and he said it could be the sending unit or the gauge. I'm wondering where my gas couldve went. Has this every happened to anyone else?
give it a few days...or a few on/off cycles that allow the fuel rail pressure to bleed off (time between each start).
the 04+ Fords are bad about this. this rears it's head usually when you leave the key on and are gassing up. the sending unit is finicky.
it it's still off after a few days...then I'd worry about getting it fixed
yeah i agree with tylus....my truck did that last summer and I had just gotten gas earlier that day....went from full to reading less than 1/8th of a tank....I ended up taking the gas cap off, replacing the cap and the starting the truck. By a few key on/ key off cycles, the gauge was back to normal later that day. I would not worry about it unless the problem persists.
I had a similar problem .... Few months ago, the fuel gauge did not go to full even when the tank was full. Re-started the truck few times then finally it went to F. Next problem was I drove it for 300 km and it stayed at F. The only way to get a new reading from the guage was to re-start the truck. It was like an old man .... hard to get it up and hard to to get down.
After 10-20 re-starts, the guage seems working fine now. I don't have an explanation why it did that.
+1 .... Thanks for looking that up Ryan50hrl. My ituation is exactly like Oldguy4. The fuel guage is working fine at this moment and I don't think the dealer will believe what I said and replace the sender. Also, don't fix if it is not broken. I just keep my fingers cross and hope for the best.
Thanks again.
Thanks again.
Mikeman
05-29-2014 01:09 AM
blackmajikf100
12-12-2010 09:02 PM
fmc400
09-28-2005 11:34 PM
