custom lift 73-79 - Ford Truck Enthusiasts Forums
custom lift 73-79
Old 01-20-2010, 10:42 PM
dillinewton's Avatar
dillinewton dillinewton is offline
dillinewton is starting off with a positive reputation.
custom lift 73-79
hey there, i have a 79 that im puttin 9 inches of suspension and 3 body lift and i have a set of 44x19.5 tires and i think my wheel wells will look alittle full but not sure? does anyone know how to with out getting into serouis engineerin. how to get more lift easily? i have have professional fab and welding skills just dont know how to safely get more suspension lift. anyone have any ideas? or will my wheel wells even look full with this combo? thanks
Old 01-20-2010, 10:44 PM
Hickfied Hickfied is offline
Hickfied is starting off with a positive reputation.
150 or 250/350?
Your wheel wells will be empty with that much lift and 44's.
Don't use a body lift, they are pointless.
Old 01-20-2010, 11:50 PM
NUTTY4X4's Avatar
NUTTY4X4 NUTTY4X4 is offline
NUTTY4X4 is starting off with a positive reputation.
body lifts are fine as long as you make all the changes to account for it and he is goin with 44s so its not like it is a work truck
Old 01-20-2010, 11:51 PM
Quote:
Why do it when you're custom fabbing a suspension lift? Why not just lift it 3" more (which would be usable lift)?
Old 01-21-2010, 12:10 AM
NUTTY4X4's Avatar
Quote:
at 9inches + you start screwing with driveline angles and having to drop t-case etc depending on application and for the price it is much easier and less "fab"
Old 01-21-2010, 12:14 AM
NUTTY4X4's Avatar
as well to get a few more inches do a rear shackle flip and and just mod the front to match
Old 01-21-2010, 12:23 AM
bigmudder150 bigmudder150 is offline
bigmudder150 is starting off with a positive reputation.
My 78 f150 has 10" in the front. It has the 7" coil spring lift and my dad back in the day placed a 3"x3" square tubing under the frame at the coil buckets to drop them down 3". It's all bolted and welded together and has been this way since the early 80's. I run 42x15 swampers with no problem. If you use the 9" springs and do what I have then you will have no problem at all with the 44's.
Old 01-21-2010, 12:31 AM
HillbillyDeluxe81 HillbillyDeluxe81 is offline
HillbillyDeluxe81 is starting off with a positive reputation.
I doubt he's "custom fabbing" anything. If he was, then he wouldn't be asking this question. He's probably referring to the Stupidlift 9" kit.
But to answer the OP's question. No, you can't get anymore lift out of the Superlift kit.......at least not safely. You're pretty much at the limit of the stock radius arm, track bar, steering, and coil spring setup. More lift would require longer suspension links, a very creative track bar, relocated spring mounts.....and flat-top knuckles for crossover steering. In other words.......pretty much EVERYTHING would be custom.....and you would use NOTHING that came with the original kit.
I actually did something similar to that with my 05 F-150. I had to buy an entire lift kit just to get the knuckles and crossmember.
Old 01-21-2010, 02:14 AM
79f350wheeler 79f350wheeler is offline
79f350wheeler is starting off with a positive reputation.
hhhhmmm
ok for starters what kind of truck do you even have? coils in the front? solid front axle? ball joints? king pins? dana 44? dana 60? bronco? fullsize? figure that out then give us a shout. if it is a fullsize with a solid front axle you you are laughing and can build a lift no problem and a steering setup. drop your t case????? why not just cut your perches and get your pinion angle right 2-3 degrees down with a cardan joint. shackle flips are a pretty good idea and a sturdy spring hanger drop in the front. plus the new super duty lift springs are an easy bolt in and pretty cheap as well. just have to drill out the front hanging to take a slightly larger bolt.
Old 01-21-2010, 09:26 AM
Thanks alot, but im really new to these extreme lifts, so if anyone could try to explain alittle bit more that would be nice and does anyone, have the same lift i have with 44s? thanks alot
Old 01-21-2010, 10:18 AM
Quote:
Telling us what truck you have will get a better explanation. 150's had coils up front, 250/350's had leafs. Also a little about what you will be using it for. Something tells me it's either mudd or pavement use.
Old 01-21-2010, 10:25 AM
Broncoholic1's Avatar
Broncoholic1 Broncoholic1 is offline
Broncoholic1 has a great reputation on FTE.Broncoholic1 has a great reputation on FTE.Broncoholic1 has a great reputation on FTE.Broncoholic1 has a great reputation on FTE.Broncoholic1 has a great reputation on FTE.
Semi air bags.
What truck do you have?
Camburg lifted van ctimrun 1968-2013 Full Size Vans 9 01-06-2015 12:56 PM
Need to clear 35s Ken904 1987 - 1996 F150 & Larger F-Series Trucks 1 01-01-2014 08:44 PM
Lift need for my truck to clear 35s Ken904 1987 - 1996 F150 & Larger F-Series Trucks 0 12-26-2013 12:37 AM
Big Suspension Lifts taylorj661 1997 - 2003 F150 60 07-11-2008 07:09 PM
Body Lift vs. Suspension Lift a_user Offroad & 4x4 4 12-31-2006 07:25 PM
Tags
73, 7379, 79, body, custom, f100, f150, ford, inch, lift, lifted, superlift, suspension, truck, trucks
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
