4r100 center support bolts question - Ford Truck Enthusiasts Forums
Old 01-20-2010, 03:50 PM
ajorn's Avatar
ajorn ajorn is offline
ajorn is starting off with a positive reputation.
When I put my Ex in drive this morning it would just rev, not engage in drive. After 3-4 seconds I was able to drive. Also does this in reverse. I was speaking with JW and he offered the suggestion to re-torque the center support bolts and see if that helps. I understand I have to remove the valve bodies to get to the bolts...
Two questions, first is can this be done with the tranny in the truck? Second does anyone have clear pictures of where the check ***** go.
Timing isn't quite right for a transmission but as soon as I can, after talking with JW that's what I'm ordering...
Old 01-20-2010, 06:22 PM
trackspeeder's Avatar
trackspeeder trackspeeder is offline
trackspeeder is gaining momentum as a positive member of FTE.
Yes this can be done in the truck. Front feed bolt is 9-13 FT. LBS. The rear two are 6-10 FT LBS.
Old 01-20-2010, 06:39 PM
ajorn's Avatar
Thanks for the reponse.
What about the check ***** and their posistion? Anyone have a pic of where they are? (I'll document this when I do it...probably on Friday)
Old 01-20-2010, 08:59 PM
mueckster's Avatar
mueckster mueckster is online now
aka Redneck Wrencher
mueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputationmueckster has a superb reputation
Here ya' go!
Name:  center support bolts.gif
Name:  check *****.gif
Old 01-20-2010, 09:09 PM
mueckster's Avatar
Torque these 3 bolts and all the other VB bolts and nuts to 89 in-lbs (80-100 in-lbs).
Name:  separator plate bolts.gif
Old 01-20-2010, 10:45 PM
ajorn's Avatar
Thanks! Exactly what I'm looking for. I'm going to try this out tomorrow if all goes well.
1988 F250 5.0 302 EFI Vacuum line diagram & EASY FIX CLAMP runner 1987 - 1996 F150 & Larger F-Series Trucks 5 06-17-2015 10:30 PM
Looking for pictures of JW Rod Garage IFS install on F1 Redgranite_Yooper 1948 - 1956 F1, F100 & Larger F-Series Trucks 6 03-03-2013 08:31 PM
4R100 Stage1 Rebuild BadDogKuzz 1999 - 2003 7.3L Power Stroke Diesel 106 08-20-2012 05:02 PM
2006 Ford F150 FX4 Bolt pattern? GrizzlyMan660 2004 - 2008 F150 1 04-02-2012 10:21 AM
4spd to a 5spd manual? Brown89f150 1987 - 1996 F150 & Larger F-Series Trucks 1 05-08-2004 05:32 PM
Tags
4r100, 99, bolt, bolts, center, diesel, feed, ford, reverse, size, slips, support, torque, transmission, troubleshooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
