95 f150 blowing fuse #18 - Ford Truck Enthusiasts Forums
Old 01-20-2010, 11:50 AM
twodazeoff twodazeoff is offline
twodazeoff is starting off with a positive reputation.
I have a 95 f150 that keeps blowing fuse #18. It would do it when you shifted out of park. I dropped the steering column and found the wires going to the o/d button had been pinched. I repaire those wires and now the fuse blows as soon as the key is turned on. Any ideas?
Old 01-20-2010, 12:26 PM
lew52's Avatar
lew52 lew52 is offline
lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.lew52 has a very good reputation on FTE.
What does the #18 fuse go to ?? Your talking about the small OD wires , you have to conect them back together one at a time & make sure there insulated good so the bare wire dosn't touch each other or any thing else ...Lew
1996 ford f150 5.0L blowing pcm fuse Michael Warnick Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 06-06-2016 12:59 PM
speedometer wiring diagram superdutyf450 1994.5 - 1997 7.3L Power Stroke Diesel 2 10-12-2015 06:41 PM
blown fuse #18 twodazeoff 1987 - 1996 F150 & Larger F-Series Trucks 1 01-20-2010 11:26 AM
Blowing 40 amp main fuse rlay302 1997 - 2003 F150 2 05-22-2009 08:51 AM
Wiring From Alternator Surging? BENG0924 1999 to 2016 Super Duty 7 01-22-2008 02:32 PM
Tags
18, 1994, 95, blowing, blows, button, f150, f250, ford, fuse, mustang, number, od, problems, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
