c6 transmission fluid - Ford Truck Enthusiasts Forums
Old 01-20-2010, 12:48 AM
Richards73 Richards73 is offline
Richards73 is starting off with a positive reputation.
My haynes repair manual told me to use dexron 3 and mercon automatic fluid but other people tell me type f
does anyone know which one is better use
Old 01-20-2010, 12:57 AM
brownfoot brownfoot is offline
brownfoot is starting off with a positive reputation.
read your dipstick, it should say "Type F"
Old 01-20-2010, 01:07 AM
it says type f i didnt no if it was changed tho because ive herd to use the other and have been having problems with the transmission
Old 01-20-2010, 04:54 AM
drop the pan, change the filter, and fill with type F
what problems are you having? does it not want to go when you first start and it is cold?
but once it warms-up it acts ok?
Old 01-20-2010, 06:30 PM
already serviced it
shifts hard and wants to stick in first gear when u first start driving
Old 01-20-2010, 07:28 PM
Danny Stroup's Avatar
Danny Stroup Danny Stroup is offline
Danny Stroup is starting off with a positive reputation.
From my online Chilton's manual:
Fluid Recommendations
  • C4 - Type F
  • C5 - Type H
  • C6 - 1976 Type F; 1977-86 DexronŽII
  • AOD - DexronŽII ATF
<!-- *** CONTENT VERSION: *** -->
Old 01-20-2010, 08:10 PM
sounds like the valve body is dirty, or can be a symptom of DexronII fluid
Old 01-20-2010, 09:06 PM
Poison Oil Racing's Avatar
Poison Oil Racing Poison Oil Racing is offline
Poison Oil Racing is starting off with a positive reputation.
Trans Fluid TSB
here is some info for you:
Ford Trans Fluid TSB
Old 01-20-2010, 09:50 PM
i have type f fluid in there right now
thanks for the help it sounds like i shoukd stick with the type f fluid
Old 01-20-2010, 09:56 PM
sometimes it doesnt like to go untill its warmed up is that normal
Old 01-21-2010, 12:27 AM
for an old transmission with a dirty valve body, yes
what did the pan look like when it was serviced, fluid clean and red or brownish with a lot of black sludge in the bottom?
a valve body rebuild kit/shift kit is about $30 and comes with detailed instructions
clean it in mineral spirits and re-assemble
what is the mileage?
Old 01-21-2010, 12:51 AM
the fluid looked good when i changed it
the bottom of the pan had some but not much dirt on the bottom
the filter was really dirty tho
were do u get the rebuit/shift kit
thanks
Old 01-21-2010, 12:52 AM
not really sure the milage 250,000?
Old 01-21-2010, 04:25 AM
I have used these before for AOD and had goo results, they were recommended by the losal transmission shop
btw, they have VERY detailed instructions along with comments, enjoyed the sometimes scarastic answers/statements
Rebuilt Transmissions Transmission Parts (transgo is company name)
Old 01-21-2010, 10:17 AM
kermmydog's Avatar
kermmydog kermmydog is offline
kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.kermmydog has a spectacular reputation.
Smile
Quote:
Yes it is normal when the seals are dried out. The old tranny guys call it "morning sickness". I have an 86 F250 4x4 C-6 that has been like that for over two years now. Although it shifts good & there is no other problems. What I did that helped get it through the last two years was add a can of TransX. That helps the seals. But this is not a cure. I'm rebuilding mine this spring.
As for fluild as stated above DEXRON II now DEXRON III is what is called for. But if you were not having issues before changing the fluild & you installed Type F hard shifting is normal because of the friction modifiers in Type F. As a rule if I remember correctly if you added Dexron to a type F trans it would be mushy shifting.
I would go to Walmart & buy a can of TransX like $5.79 were the parts houses want $9. See what happens. TransX will not hurt anything. It has been around since I was a teenager in the early 60s. We used it then.
The other option if you have the wrong fluid is to add a can of LubeGard it is a friction modifier.
Hope is helps.
Craig
Help needed! Blackexcursion Excursion - King of SUVs 6 10-05-2016 02:16 PM
correct brake fluid for 2015 f350 don123 1999 to 2016 Super Duty 7 06-22-2016 12:59 PM
brake fluid? jmtbiggin Large Truck 1 10-26-2014 10:21 PM
Automatic transmission fluid change Rusty_S Clutch, Transmission, Differential, Axle & Transfer Case 14 06-23-2012 02:28 PM
Differential Fluid Change onuredneck707 6.0L Power Stroke Diesel 5 03-30-2011 05:09 PM
Tags
1977, 1979, c6, fluid, ford, kit, online, problems, rebuild, specifications, specs, transmission, truck, trucks, type
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
