What are you using for calipers , rotors & etc ? What yr. 9 " ? This may be the key as to if you can use existing e-brake cables .There is a certian GM caliper to use .
I have a '72 9" in my '49. I used the cables from the original rear end and hooked them up as they were originally. They fit right on the 9".
My original cables were toast. I bought new ones - probably from Sacto Vintage Ford - it was 10 years ago and my memory is only good for 10 minutes most days............
