You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
My 2005 F350 5.4L 3V is throwing DTC P2104 and P2135. From my research, it appears that the "Throttle Position Sensor" needs to be replaced. The Part# is 6L2Z9B989C and costs $59.98 at FTEPARTSGUY.com.
How difficult is it to replace this part? Do I need to have the PCM re-flashed as part of the repair?
Thanks!
__________________
Andrew
2005 F-350 XL, 4X4, RCLB, 5.4L 3V, TorqShift®, 4.10 LS, K&N CAI Kit, SCT Livewire w/ Custom Tunes from 5 Star Tuning
It's fairly easy. Just disconnect the battery, remove the air intake plastic housing at the throttle body, replace the sensor, clear the code; then everything should be OK. I also would check for any shorted or grounded wire from the sensor to the GEM too.
Don't you just love it when a plan comes together!
Rick...
Quote:
Originally Posted by Furian
I replaced the throttle position sensor today... that was the problem. Thanks for your help khangmia!
__________________ ______________________________ Shut up. Just shut up...You had me at "I like your truck" ------ (How-to Use The FTE Search Tool) ------
__________________________________________ .....'02/EphTreeFiddy/LarryAt/Six.Ate/CC/LB.....
Do I really need to add a smiley face to every sarcastic comment?
Just wanted to say thanks for posting this. Autozone read the codes from my 2006 F250, P2106 & P2135. Found this post, changed out the TPS and no more hesitation or sputtering. AND $60 instead of $460 - nice.
Yesterday, my 2005 Expedition dash lit up with an array of service lights & messages (check engine, throttle body sensor, etc.), and shut down during driving. Dealer advises problem was with throttle body sensor & along with a number of other issues, recommended replacing sensor PLUS full cleaning of fuel injectors. Expensive procedure, and had just had dealer do a carbonic flush of injectors about 20,000 miles ago (currently have 90K miles).
Anyone feel strongly about the reccomendation to flush and manually clean all injectors in the 2.4L 3V?
This forum is owned and operated by Internet Brands, Inc., a Delaware corporation. It is not authorized or endorsed by the Ford Motor Company and is not affiliated with the Ford Motor Company or its related companies in any way. Ford® is a registered trademark of the Ford Motor Company.
