Go Back   Ford Truck Enthusiasts Forums > General > Projects
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Projects Share with other members the details about your project truck or SUV. Old or new, gas or diesel, its all welcome here!
  #1 (permalink)
Old 01-19-2010, 11:09 AM
82ford302's Avatar
82ford302 82ford302 is offline
Garage is empty, add now
82ford302 is starting off with a positive reputation.
76 F250 daily driver/project
getting close to tax time so i figure i'd make something with this truck i got. it has alot of rust and i dont think that its worth keeping the cab and bed. the only thing thats actually original to the frame is just the cab shell. i have a 79 cab that is virtually rust free that i will be swapping over. still havent got a bed yet for it. i'll update as the progress goes, but for now heres my rust situation.
someones idea of a cab mount fix for the pass. side
Click the image to open in full size.
LH front cab mount. you can tell someone cut one from another truck and just welded it to the old one on the cab
LH floor and part of the rocker panel
LH lower firewall
LH front lower door post
LH lower radiator support
LH upper door post
RH lower firewall
RH lower door post
RH rocker panel
those were the only pics i took so far. both doors are shot as well. the only thing that really survived was the hood, inner fender aprons and the roof lol.
  #2 (permalink)
Old 01-31-2010, 01:17 PM
Customcab's Avatar
Customcab Customcab is offline
Customcab has a good reputation on FTE.Customcab has a good reputation on FTE.
Mike
Looking forward too seeing your progress. Just recently put a 76 F150 body onto the chassis & drive train of a 74 Highboy. Pic in my gallery now a 76 F250 highboy daily driver.
Mitch
__________________
Mitch
63 F100 LWB 302/AOD (Orphan box) Daily Driver.
62 F100 LWB 292/3spd (Uni-body Big Window)
57 F100 SWB 351C/FMX; (Big Window)
93 F150 4x4 Regular Cab Daughters 2nd truck
62 Flairside SWB "Wife truck"
  #3 (permalink)
Old 01-31-2010, 05:28 PM
82ford302's Avatar
thats a nice truck there Mitch. mine probly wont look that good for awhile since im on a budget lol. but someday it will look good.
  #4 (permalink)
Old 02-02-2010, 08:52 AM
Customcab's Avatar
Mike; thanks for the comment;
This was built on a 3K budget as well. I started off with a 74 F250 Military order truck; kept the drive train & chassis and bought 76 F150 complete minus tailgate and used the body from it. Strictly on a budget; since I just finish a 78 model the same year for my daughter as her first driver; money was & is tight.
The biggest advantage was having a good friend's that's all fords and one with a complete shop & paint booth. (I got people's!!!)
But your on the right track and start with getting the basis repairs done and slowly but surely the process will come thru. As I mention I'm looking forward to seeing your success as well.
( if I can help just pm me!)
Mitch
__________________
Mitch
  #5 (permalink)
Old 02-06-2010, 08:13 PM
82ford302's Avatar
thanks Mitch for the help, i'll probly need it lol. a new problem has come up on my engine that is going to need looked at first. oil pressure isnt all that good, so i'm going to take the oil pan off tomorrow to see if the pickup screen is clogged. i also have a light knocking sound coming from the front but i think its the timing chain slapping the cover. it was a little loose when i tore the cover off awhile back. i'll know more tomorrow hopefully if the weather does'nt mess things up lol.
  #6 (permalink)
Old 02-08-2010, 06:10 PM
82ford302's Avatar
got the timing cover and the oil pan off. timing chain was sloppy and rubbing on the timing cover a little bit. the oil pump screen had some silicone stuck to it. i guess whoever rebuilt the motor awhile back got a little silicone happy lol.
ordered a few parts today which consist of:
comp cams magnum double roller timing chain/gear set with steel gears
melling standard pressure/volume oil pump
associated gaskets for install
skyjacker 4" lift kit with rear springs and hydro shocks
3" steering block for steering correction
new transfercase bushing kit since the ones on it now are trashed
should have most of the parts by this friday. im still debating on wether to buy the tires i want new or used but not really concerned about them at this point. will update as parts come in.
  #7 (permalink)
Old 02-13-2010, 10:29 AM
82ford302's Avatar
ok, some good and bad news.
good news is i got some of the parts that were ordered. got the engine parts and half of my lift kit. should have the other 3 shocks on tuesday, but no idea on the comp box thats coming from skyjacker.
bad news is, after all the stuff was ordered my sewer line decided to burst and now have to fix it before i work on the truck lol. its a never ending battle. and also the steering block from bronco graveyard is on backorder so i probly wont see it for another 2 weeks. and also the new 38's i ordered are on backorder as well for almost 3 weeks.
anyways heres a few pics of the stuff i got so far
  #8 (permalink)
Old 02-15-2010, 03:57 PM
82ford302's Avatar
finally got the comp box from skyjacker today. other 3 shocks will be coming from ups tomorrow afternoon. 2 of the 38" swampers came in today also. cat decided he needed to investigate them lol.
  #9 (permalink)
Old 02-19-2010, 09:42 PM
Customcab's Avatar
What's the lift height going to be? also price of your 38's?
Mitch
__________________
Mitch
  #10 (permalink)
Old 02-19-2010, 10:58 PM
82ford302's Avatar
dunno what the lift height will end up at. with the skyjacker 4" and the 3" body lift and 38's it will be tall lol. the 38 12.50 16.5 for the set of 4 ran me a little over 1200 shipped. just waiting on back ordered parts. mainly 2 more tires and 2 more shocks.
  #11 (permalink)
Old 03-02-2010, 03:54 PM
82ford302's Avatar
well i got the 2 front shocks in yesterday. other 2 tires should be here in about 2 weeks or less. just waiting on the ground to dry up a little to swap it all out lol.
  #12 (permalink)
Old 03-16-2010, 05:18 PM
82ford302's Avatar
the other 2 tires finally came in today. hopefully i will be able to put the lift and tires on this weekend or the next (depending on the wifes work schedule). my original plans have changed for the lift a little bit. im still going to use the lift kit i bought, but do a shackle flip and hanger drop in the back, and a hanger drop and custom shackles in the front. i might be trading these 38's off for a set of new 42-15-16.5 tsl's just so the truck dont look too rediculous with the bigger lift.
more info to come, stay tuned lol.
  #13 (permalink)
Old 03-17-2010, 04:59 PM
82ford302's Avatar
well my project is going to be postponed for a while till i figure out where i can store this truck out of sight and out of mind. some punks here in town thought they would vandalize my truck again for the 2nd time. this time they almost wiped out my whole electrical system and almost cost my sons and my own life since the wire for my gas tank sender caught on fire and was burning right on the terminal on the gas tank. life just doesnt get any better lol. will update as things progress
  #14 (permalink)
Old 03-17-2010, 06:55 PM
COMPLIT1107's Avatar
COMPLIT1107 COMPLIT1107 is offline
COMPLIT1107 has a good reputation on FTE.COMPLIT1107 has a good reputation on FTE.COMPLIT1107 has a good reputation on FTE.
Sorry to hear...
In the meantime, hang a sign, saying:
This is my truck and I will protect it, just like the first one (and I have no problem going back to prison - either !)
Keep your powder dry and your gas away from the sending unit!
__________________
John
English is my 2nd language, I have no 1st ... & I Don't trust a truck younger than I am
1947 Ford 1/2T http://www.ford-trucks.com/forums/87...way-guide.html
1950 Ford F-1
1951 Ford F-1 Panel http://www.ford-trucks.com/forums/11...ese-years.html
1953 F-100
  #15 (permalink)
Old 03-17-2010, 07:30 PM
82ford302's Avatar
done had the cheif of police over here. said my truck wasnt the only one in the past week that was messed with. told him what i was going to do, he said i didnt hear anything you said. guess its free for all here in this town lol. only been here 2 years.
Tags
390, 76, 78, backorder, bronco, daily, driver, f250, ford, graveyard, headers, kit, lift, project, timing, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
