D60 front axle - Ford Truck Enthusiasts Forums
D60 front axle
Old 01-19-2010, 12:04 PM
Southern Buckers's Avatar
Southern Buckers Southern Buckers is offline
Southern Buckers is starting off with a positive reputation.
D60 front axle
I have found a used D60 Front axle from a 1995 F-360, and I just wanted to make sure it will still fit under my 1997 F-250. I have the twin I beam front end under my truck now and hate it, so I am looking at doing a swap in the near future. Here is the ad the guy has where he is selling it. How much do these axles usually run when purchasing one?
I have axles for sale out of a 1995 F350 diesel. I will sell together as a pair or separately. The front is a Dana 60 with 4.10 gear with manual hubs. The rear is Sterling 10.25 with a 4.10 rear gear. Both worked well, this was a parts truck and these are some of the last pieces left. $1600 for both axles or $1000 if bought separately. The front end is unbolted out of the truck with springs attached the rear end is still attached to the frame.
Old 01-19-2010, 12:16 PM
79f-250custom's Avatar
79f-250custom 79f-250custom is offline
79f-250custom is starting off with a positive reputation.
i think any axle from 85 to 97 should fit.
Mitch
Old 01-19-2010, 01:13 PM
RRranch RRranch is offline
RRranch is gaining momentum as a positive member of FTE.RRranch is gaining momentum as a positive member of FTE.
Make sure the rear isn't from a cab and chassis truck if you get it.
The front end should be fine though.
Old 01-19-2010, 02:50 PM
Muktown's Avatar
Muktown Muktown is offline
Muktown is gaining momentum as a positive member of FTE.Muktown is gaining momentum as a positive member of FTE.
if you only buy the front make sure you have the 4.10 gear ratio in the back of your truck otherwise you will either have to swap gears or buy both axles
Old 01-19-2010, 03:33 PM
93f1505.0L's Avatar
93f1505.0L 93f1505.0L is offline
93f1505.0L is starting off with a positive reputation.
It should work, X2 on the gears. I just did the swap about a month ago. If you have any guestions PM me. I would get the front springs too if you can, they sit a little higher. Grab the rear blocks too to level it out.
Old 01-19-2010, 03:35 PM
The gear tag on the front should say 4.09 ratio.
Old 01-19-2010, 03:50 PM
my truck has 4.10's also
Old 01-19-2010, 11:45 PM
joe_13894 joe_13894 is offline
joe_13894 is gaining momentum as a positive member of FTE.joe_13894 is gaining momentum as a positive member of FTE.
That's pretty typical for a good D60. I hear stories of cheaper ones being found, but unless you're lucky they tend to go in the $800 to $1000 range.
The rear axle is only worth a few hundred. They are VERY common.
Old 01-20-2010, 06:06 PM
PIKE's Avatar
PIKE PIKE is offline
PIKE is starting off with a positive reputation.
Prices for 60 axles vary alot by region,thats probably not a bad price if you dont have to rebuild.Even if it is a dualie front axle you already have the parts to convert it on your dana 50,the hubs will interchange,brakes are the same.Grab the springs,spring clamp on the drivers side,track bar,track bar bracket,sway bar and attaching brackets,driveshaft,and calipers anything else you can thats really not a bad price if you get everything.Try to get the steering parts too tierod to steering box.For small misc.parts see MAD 4x4.Enjoy
Old 05-16-2010, 11:00 PM
rn360908's Avatar
rn360908 rn360908 is offline
rn360908 is starting off with a positive reputation.
Yeah it should work, I put a king pin dana 60 from a 1985 f-350 in my 1997 f250. I think the price seems high but I bought a whole truck for 800. Took the dana 60 out and put under my truck and then took my junk spicer 50 and put under donor truck and sold the truck for 700. So I end up with a perfect KPD 60 and new nerfbars for $100
Old 05-17-2010, 09:09 AM
Fullcrew7.3's Avatar
Fullcrew7.3 Fullcrew7.3 is offline
Fullcrew7.3 has a good reputation on FTE.Fullcrew7.3 has a good reputation on FTE.
I paid $110 for a complete truck minus engine. I do think that's a little steep, but not too far from average.
Old 05-17-2010, 09:35 AM
Neal 97 250's Avatar
Neal 97 250 Neal 97 250 is offline
Neal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud of
OK so you two can quit bragging now.
I thought I got a good deal at $250 but that is awesome.
Detroit Locker FordTruckGuy96 1987 - 1996 F150 & Larger F-Series Trucks 34 08-11-2016 06:41 PM
SAS questions (beating a dead horse) Brysonw 1987 - 1996 F150 & Larger F-Series Trucks 12 05-30-2014 01:17 PM
Re gearing a rear end Eallend7 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 25 04-19-2013 05:06 AM
4.10 or 4.56 Holland416 1987 - 1996 F150 & Larger F-Series Trucks 12 02-06-2013 02:13 PM
front axle question and new member old red 73 1973 - 1979 F-100 & Larger F-Series Trucks 3 09-06-2011 04:09 PM
Tags
1995, 1997, 410, 4x4, 60, 73, 95, axle, axles, dana, dually, f250, f350, ford, front, rear, sale
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
