Go Back   Ford Truck Enthusiasts Forums > Diesel > General Diesel Discussion
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
General Diesel Discussion SPONSORED BY:
  #1 (permalink)
Old 01-19-2010, 10:28 AM
fast_fred fast_fred is offline
Garage is empty, add now
fast_fred is starting off with a positive reputation.
Will not turn over?
I have a 2002 E550 with a 7.3L Powerstroke. I spent a few days cranking the truck over in the cold weather to finally get it to start; and I let it run for an hour before turning it off. I went out the next day to start it again and all it will do is give a clicking sound. The battery is fully charged and I do have the truck plugged in. Did I do something to cause this from the previous day of trying to continious starting it? My thought might be a bad starter selenoid? Any thoughts?
Thanks
Fred
  #2 (permalink)
Old 01-19-2010, 03:20 PM
SteveBricks's Avatar
SteveBricks SteveBricks is online now
2006 Ford F-250
My Garage
SteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputationSteveBricks has a superb reputation
Have you made certain the battery cables are sound and their connections are clean?
__________________
'06 F250 6.0 / '94 F350 7.5
Regional Chapters Moderator
SoCal FTE
Join our Chapter *HERE*
9/21/54 - 9/25/09
  #3 (permalink)
Old 01-19-2010, 07:49 PM
powerstroke72's Avatar
powerstroke72 powerstroke72 is offline
powerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputationpowerstroke72 has a superb reputation
+1 on what Steve said. My next guess would either be the solenoid or the starter itself.
__________________
John
2011 F-350 4x4 Lariat Ultimate, Oxford White / Pale Adobe 6.7L PSD 3.55 ELD / Gone but not forgotten.
2013 Ford Taurus SHO, Tuxedo Black / Black Leather
Moderators, Guidelines, and How They are Enforced / FTE Forum Guidelines
Currently truckless
  #4 (permalink)
Old 01-19-2010, 08:19 PM
The battery cables are connected sound and the battery's are both charged. Is the solenoid located on the starter? How do I check to se if its good? Or do I just remove the starter and take it in to be tested?
Thanks for the help, keep it coming.
Fred
  #5 (permalink)
Old 04-07-2011, 05:39 PM
brassford brassford is offline
brassford is starting off with a positive reputation.
I am having the same problem what did you find was the issue?
  #6 (permalink)
Old 04-07-2011, 05:44 PM
fast_st fast_st is offline
1989 Ford F-250
fast_st is starting off with a positive reputation.
Didn't see a followup from the OP, with a diesel, get a battery tester, one of the $20 resistive ones works fine.
remove and clean every cable connection, batteries, grounds, starter. Charge each battery seperately and test each one.
If you have just a click, it could be the upper starter solenoid, look for voltage with a test light on the outbound side when the key is turned to start. If you have voltage, your next stop is the starter itself.
  #7 (permalink)
Old 04-07-2011, 11:29 PM
joshofalltrades joshofalltrades is offline
1987 Ford E-Series Van
joshofalltrades is gaining momentum as a positive member of FTE.
"taking it in" to be tested shouldn't be necessary, but it sounds like fred is not familiar with bench-testing his own starter, so i'll briefly describe the process. with the starter out of the truck, support the starter in a vise (by its mounting flange only, don't crush it), then connect jumper cables or other heavy cables from a battery: ground of battery to body of starter (mounting flange), then momentarily connect the positive cable to the stud where the hot wire connects. the starter should roar to life. note: avoid arcing of the terminal by having a solid connection of the positive cable to the starter, then making the final connection at the battery. note2: if a vise is not available, most starters can be held down by a man, but expect it to try to jump out of your hands.
if the starter works for a bench test, but not in the truck, its probably not getting power. rarely have i seen a good starter getting good power just click and not crank the engine, and those were due to seized engines, which i don't expect is your case.
  #8 (permalink)
Old 04-08-2011, 05:19 AM
mistakenID mistakenID is offline
mistakenID is gaining momentum as a positive member of FTE.mistakenID is gaining momentum as a positive member of FTE.
The OP last replied to this thread over a year ago.
__________________
86 F-250 4x4
Cummins BT 5.9
GearVendor O/D
Dads 87 F-250
4x4-5sp 6.9 Turbo
73,000 original miles
  #9 (permalink)
Old 04-13-2011, 07:54 AM
1989 Ford F-250
Quote:
Four years is plenty of time to fix your starter, someone get over there and kick his axle for not giving a good followup.
Tags
06, 2000, 2005, 2008, 60, battery, change, crank, diesel, e150, excursion, f250, ford, locked, truck, turn, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
