1989 f150 build - Ford Truck Enthusiasts Forums
1989 f150 build
Old 01-19-2010, 08:33 AM
SACGNS SACGNS is offline
SACGNS is starting off with a positive reputation.
1989 f150 build
Ok so here is my plan I am doing most of this threw clifford performance. I am using there super rebuild kit along with the full setup for the weber triple side draught intake manifold. Ontop of that I will be putting on a ststurbo kit, a twin turbo rearmount kit. My question here is any sugestions on somethin I may need an also anyone know clifford performance? I wonder if there rebuild kit is strong enough.
Old 01-19-2010, 09:06 AM
frgtflrcn frgtflrcn is offline
frgtflrcn is starting off with a positive reputation.
well with the lack of info, i am guessing you have a 300 CI straight six? make sure the compression isnt raised to high for the turbo. you will also need some major fuel system upgrades to handle the turbo side of things and dont cheap out on computer tuning stuff, a tune will make or break theengine
Old 01-19-2010, 09:33 AM
Oh my bad here's some more info, its a 4.9l 300 5 speed. The turbo setup comes with everythin I need from programing to inline fuel pump oil pump 1000cc injectors all lines needed, intercooler. All pipes eveythin I need. I'm not to concerned about compression because higher compression will lower spool time on the turbos only prob is the high compression may requirer goin from regular gas to premium. My only concers are the rods I have a lot of experience with 4 cylinder audi mortors but this will be my first for so I'm not sure on the strength of the rods. Also any suggestions on suspension setup? I want to lower the truck not sure how much tho.
Old 01-20-2010, 11:58 AM
6CylBill's Avatar
6CylBill 6CylBill is offline
6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.6CylBill has a great reputation on FTE.
SACGNS, have you thought about installing a Gen1 Lightning suspension system? That's about as perfect as it gets for handling and stance, man.
Old 01-20-2010, 03:55 PM
actually i havent, how much modification would be needed do u know
Old 01-20-2010, 03:58 PM
6CylBill's Avatar
I'm sorry, I had a brain fart. I thought you had a 92-96 model F-150. I don't think the Lightning parts would bolt in your '89. Sorry man, I wasn't thinking!
Old 01-20-2010, 04:11 PM
hey good idea tho, that is my only snag rite now is findin a proper suspension setup. i was thinking of just putting airride but still no good setup it would all have to be custom
Clifford Performance Upgrade 223 tompmatthews 1948 - 1956 F1, F100 & Larger F-Series Trucks 2 01-01-2016 01:28 PM
Clifford Header Quality? F-250 restorer Ford Inline Six, 200, 250, 4.9L / 300 1 08-28-2015 02:17 PM
Are high volume oil pumps bad for our engines? Carloespo Ford Inline Six, 200, 250, 4.9L / 300 9 06-08-2015 09:03 PM
Clifford Intake / Weber 38 Carburetor KsCop 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 17 07-30-2014 05:58 PM
Clifford Performance Valve Cover F-250 restorer Ford Inline Six, 200, 250, 4.9L / 300 0 02-03-2013 11:15 PM
Tags
1989, 89, 94, build, builds, f150, flareside, ford, raised, tuning
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
