Timken 2-speed axle - ever seen one ?? - Page 2 - Ford Truck Enthusiasts Forums
Old 01-26-2012, 06:05 PM
38 coupe's Avatar
38 coupe 38 coupe is offline
38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.38 coupe has a great reputation on FTE.
The 2-speed axle under the 30s and 40s Fords was the Columbia, not the Ruckstell.
A picture of the Ruckstell can be seen in this thread: Model T Ford Forum: Ruckstell or auxiliary transmission, opinions wanted.
The Columbia axle was available from 34 to 48 for new Fords. A picture of a Columbia can be seen here: Redirect Notice
Old 01-27-2012, 07:02 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Columbia Two Speed: Company owned by Erret Lobban Cord (who also owned TWA-Transcontinental & Western Air, Lycoming, and ACD-Auburn/Cord/Duesenberg). AFAIK, first installed in 1935 Auburn 851's.
The only Ford products I've seen (vacuum controlled) Columbia two speeds installed in: 1941/48 Ford/Mercury Passenger Cars. I had a '47 Ford woody with one, a pal has several '46/48 Fords and Merc's w/Columbia's.
Maddux Inc., the CA Lincoln Distributor, founded TAT-Transcontinenental Air Transport in the 1920's, merged it with Western Air Express. The aircraft were Ford Tri-Motors initially.
Cord bought TWA when Maddux went bankrupt, then with his fortunes declining, sold it to Howard Hughes. Hughes later changed the name to Trans World Airlines.
Old 11-30-2012, 11:29 PM
furius furius is offline
furius is starting off with a positive reputation.
if i didn't live so far away i would take you up on that rear axle. that front axle is nice but i wouldn't have a use for it. plus i am half snowed in already all projects around hear stop when it snows. i have enjoyed this thread i know its early but merry christmas
Old 12-01-2012, 05:03 AM
Quote:
Originally Posted by Packard V8 View Post
The Ruckstall 2-speed rear axle was a popular dealer-installed option on Fords from the 20s to the 40s.
Ruckstall's AFAIK, were only installed in Model T's.
Old 02-21-2014, 07:33 PM
ChristopherB ChristopherB is offline
ChristopherB is starting off with a positive reputation.
Good Evening All! I realize that this thread is over two years old; however, I was curious if either of the two axles (Eaton 2 Speed and Front) are still available? Please adivse - thanks!
Old 02-21-2014, 07:41 PM
Wheel seals Mike1 1999 to 2016 Super Duty 0 11-30-2016 09:52 AM
D60 hub/axel exploded view and part numbers fordpride 1994.5 - 1997 7.3L Power Stroke Diesel 7 09-13-2016 10:57 PM
1st Post - New (to me) 2003 w/ 231,000 miles - Needs front suspension work done12many2 Excursion - King of SUVs 43 07-25-2015 07:29 AM
1950 F2 Rear Grease Seals Cougar54 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 08-10-2014 10:57 AM
timken rear axle revans9295 1948 - 1956 F1, F100 & Larger F-Series Trucks 17 03-23-2014 10:13 AM
Tags
2speed, 450, axle, axles, book, eaton, end, face, ford, herrington, marmon, rear, speed, split, timken, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
