Illinois Chapter Join Chapter Leader: wpnaes
Off topic: ATTN: any HVAC techs
Old 01-18-2010, 10:45 PM
BobbyDiesel71's Avatar
BobbyDiesel71
BobbyDiesel71 is offline
I am looking to find a HVAC installer/tech that can help their IL FTE chapter leader
I have a Lenox G50/Elite series furnace that has been kicking On and OFF
error code is FAULTY IGNITER
I have a 10 year parts and labor ext warranty from a local HVAC shop and want to confirm from someone knowledgeable to tell me if its a cheap fix or expensive.
thanks
bob
Old 01-19-2010, 08:31 AM
carras's Avatar
carras
carras is offline
I'm not an HVAC tech, but had a similar problem. The tech cam in and cleared scale from a small vacuum hose leading to the heat chamber. He used a small allen wrench to "rod it out". Said that this was common on systems that have digital thermostats used to lower temp>2 degrees during the day. Said that scale develops due to moisture.
No problem since. Good Luck
Old 01-19-2010, 05:37 PM
BobbyDiesel71
thanks i have a commercial HVAC friend coming over today to check my furnace
Old 04-17-2010, 12:46 PM
worm5932's Avatar
worm5932
worm5932 is offline
i know its been a while, but what ever came of this problem?
