Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Mid-West Region > Illinois Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Illinois Chapter Join Chapter Leader: KOESTNER
  #1 (permalink)
Old 01-18-2010, 10:45 PM
BobbyDiesel71's Avatar
BobbyDiesel71 BobbyDiesel71 is offline
2002 Ford F-350
BobbyDiesel71 has a good reputation on FTE.BobbyDiesel71 has a good reputation on FTE.
Off topic: ATTN: any HVAC techs
I am looking to find a HVAC installer/tech that can help their IL FTE chapter leader
I have a Lenox G50/Elite series furnace that has been kicking On and OFF
error code is FAULTY IGNITER
I have a 10 year parts and labor ext warranty from a local HVAC shop and want to confirm from someone knowledgeable to tell me if its a cheap fix or expensive.
thanks
bob
__________________
DP TUNED
swamps single shots
02 F-350 lariat srw,supercab longbed 4x4 FX4
Transgo Tugger II, TRU-COOL 4739, AFE stage II intake, Bully Dog 5" turbo back exhaust Dieselsite coolant filter Rhino liner rocker panels
  #2 (permalink)
Old 01-19-2010, 08:31 AM
carras carras is offline
Garage is empty, add now
carras is starting off with a positive reputation.
I'm not an HVAC tech, but had a similar problem. The tech cam in and cleared scale from a small vacuum hose leading to the heat chamber. He used a small allen wrench to "rod it out". Said that this was common on systems that have digital thermostats used to lower temp>2 degrees during the day. Said that scale develops due to moisture.
No problem since. Good Luck
  #3 (permalink)
Old 01-19-2010, 05:37 PM
2002 Ford F-350
thanks i have a commercial HVAC friend coming over today to check my furnace
__________________
DP TUNED
swamps single shots
  #4 (permalink)
Old 04-17-2010, 12:46 PM
worm5932's Avatar
worm5932 worm5932 is offline
2001 Ford F-250
worm5932 is starting off with a positive reputation.
i know its been a while, but what ever came of this problem?
__________________
Casey -2001 f250, ex cab, long bed, lariat, 4x4, 20 inch pro comps, goodyear wranglers, warn premium hubs, 6637, ccv, wheel, wildman tunes, auto meter guages, AIH delete, 4" magnaflow -2003 expedition, eddie bauer, intake, throttle body spacer, programmer -1986 f150, 302 roller motor, AOD, shift kit, 9" locker 4.11, 3/5 lowering kit, rode HARD and put away wet, waiting on 3rd frame off! -2007 victory vegas 8-ball, stage 1
Tags
2008, ball, elite, furnances, g50, lennox, problem, series, vacuum, vegas, victory
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
