1959 factory build 4x4 or not??
I have a 59 f-100 V.I.N is F10J9K54726 this website said its a 59 f100 4x4. But where a have read things on the net said its NOT a factory built 4x4. The same V.I.N numbers are on the cab glove box, the frame, and the title. The cab does have the piece from the door piller down to the floor board behind the seat. Could someone PLEASE clear this up for me?? Thank you in advance for any info.......
One of the publications I have cited '59 as the 1st year 4x4 was a Ford cataloged option. And here's the post Bill (number dummy) repiled to on a 59 F100 4x4:
https://www.ford-trucks.com/forums/9...-f100-4x4.html
Im not real sure where the data plate is.. Ive looked all over and cant find it, May not be there, Might be long gone.The title matches all the other numbers on the truck, Glove box and the frame rail......Anything else i could look for?? Thank all of ya'll for your commets............Brandon
Factory 4-wheel drive, your vin has the code A which is the front axle code.
118= 8ft bed
S= Special order paint
F18J is the model code, F18 is 4 wheel drive(still havent figured out the J, but I think it matches the engine)
26H= 26th of august built
F= 4 speed trans
A= Front axle ratio of 3.89:1
02=Rear axle open diff 3.89:1
5600=gross vehicle weight
126=net horsepower
4000= rpm at which the horsepower was rated
6602= D.S.O District sales office code
Your Vin=
F10=f100
j=223 six cyinder
9=1959
K= Kanas city
54726= build #
118= 8ft bed
F= 4 speed trans
126=net horsepower
Your Vin=
F10=f100
j=223 six cyinder
9=1959
K= Kanas city
54726= build #
