oasis reports
I'd love an oasis report for the truck I just bought. Here's the VIN: 1FTNX21F3YEC35635
I've seen something about the Oasis just showing the last year, but there is also a way to get full warranty history, is that possible? You can email me at hpcbmw@yahoo.com.
Thanks for the help!
Good man.
I'll have to get you mine asap for this also.
oh wait, i think i have it on here.
*looks*
2FTHF26F2RCA49067
I'd also like to report that windows seven found no files named 2FTHF26F2RCA49067. Hahah!
*looks*
2FTHF26F2RCA49067
hpc
you have a recall 09s09 cruise modifcation still open on your f-250.
Cust Comments: CUST SAYS THE KEY STICKS IN THE START MODE AND DOES NOT RETURN INTERMITTENTLY CAUSING THE STARTER TO GRIND
Tech Comments: 1 VERIFIED CONCERN. R AND R IGNITION LOCK CYLINDER AND LUBRICATE. START SEVERAL TIMES. COULD NOT GET TO STICK
Cust Comments: CUST SAYS THE TRUCK ROLLS EXCESSIVLYIN PARK ON THE PARK PAUL ABOUT 6 8 INCHES
Tech Comments: FLUID OK. ROAD EST SHOWS TRANS SHIFTS PROPERLY AT THIS TIME. PARK PAUL WORKS OK. NOTE, MUST APPLY E BRAKE BEFORE PUTTING
Cust Comments: CUST STATES POWER POINT INOP
Tech Comments: VERIFY CONCERN. FOUND GPS TO BE DRAWING TO MUCH AMPERAGE. FOUND BLOWN FUSE REPLACED FUSE RETESTED AND VERIFIED REPAIR
Cust Comments: CUST STATES THE TRUCK STALLS WHILE DRIVING HAD THE TRUCK TOWED IN DIAG AND REPORT
Tech Comments: TEST SYSTEM STALLING CONCERN PERFORM DIESEL DIAG FUEL SYSTEM AND INTAKE SYSTEM GOOD ROAD TEST WITH WDS MONITOR AND RECORD PIDS FOUND LOSS OF RPM SIGNAL W/STALL REPLACE CAM SHAFT SENSOR AND RETEST ALL OK
Cust Comments: SUBMIT FOR REFUND TO 07S57 ******* MOTORS INVOICE #*****11.18.2002 $100.00 DEDUCT
1FMNU41SX1EB19157 That is for a ford excursion i plan on looking at this week.....if you could help me out i would be awesome.
brown
<TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>VEHICLE TOWED IN NO START CRANKS THEFT LIGHT FLASHES</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>NO GROUND IN HARNESS EEC (QUICK TEST) DIAGNOSIS</TD></TR></TBODY></TABLE>
<TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>RECALL 01S21 DUE</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>PERFORMED SAFETY RECALL</TD></TR></TBODY></TABLE>
<TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>MLDG ON PASS SIDE DOOR LOOSE.</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>CHKD MLDG & REINSTALL</TD></TR></TBODY></TABLE>
<TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>BRAKES SQUEAL WHEN IN 4X4</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>INSPECT & CLEAN FRT BRAKES</TD></TR></TBODY></TABLE>
<TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>HEADLIGHTS OUT OF ADJUSTMENT</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>CHKD & FOUND HEADLIGHT RETIANING CLIP MISSING. REPLCED CLIP</TD></TR></TBODY></TABLE>
<TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>LOCK ON LEFT FRT IS INOP</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>CHKD & REMOVED CYL & REPLACED CYL ASSY, RECODE LOCK</TD></TR></TBODY></TABLE>
<TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>PANEL ON REAR DOOR ON RT IS LOOSE</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>CHKD & FOUND MLDG CLIP BROKEN, REPLACED MLDG</TD></TR></TBODY></TABLE>
<TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>CUSTOMER STATES THAT VEHICLE HAS RECALL RECALL 05S28</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>PERFORMED RECALL 05S28 AS INSTRUCTED</TD></TR></TBODY></TABLE>
