oasis reports - Ford Truck Enthusiasts Forums
Michigan Chapter Join Chapter, Leader: Toyman
oasis reports
Old 01-18-2010, 09:19 PM
fordmasterdieseltech fordmasterdieseltech is offline
fordmasterdieseltech is starting off with a positive reputation.
oasis reports
hello all, if you need an oasis report done, post of your vin or pm your vin and ill run an oasis for you. give me some time to get back with you as im working during the day and cant always check the board. thanks chris
Old 01-19-2010, 10:53 AM
hpcbmw's Avatar
hpcbmw hpcbmw is offline
hpcbmw is starting off with a positive reputation.
I'd love an oasis report for the truck I just bought. Here's the VIN: 1FTNX21F3YEC35635
I've seen something about the Oasis just showing the last year, but there is also a way to get full warranty history, is that possible? You can email me at hpcbmw@yahoo.com.
Thanks for the help!
Old 01-19-2010, 11:06 AM
Talyn's Avatar
Talyn Talyn is offline
Talyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud ofTalyn has much to be proud of
Good man.
I'll have to get you mine asap for this also.
oh wait, i think i have it on here.
*looks*
2FTHF26F2RCA49067
I'd also like to report that windows seven found no files named 2FTHF26F2RCA49067. Hahah!
Old 01-19-2010, 11:16 AM
hpc recheck your vin and repost. vin is nott valid
Old 01-19-2010, 11:18 AM
tayln oasis only goes back 10 years the only info thatt come up for that vin is the fact therre is a rrecall 09s09 cruise control deactivation still open on it. ttake it to the dealer tot have it performed free of charge.
Old 01-19-2010, 11:26 AM
hpcbmw's Avatar
Looks like I had the last number wrong: 1ftnx21f3yec35636
Thanks!
Old 01-19-2010, 11:33 AM
hpc
you have a recall 09s09 cruise modifcation still open on your f-250.
Cust Comments: CUST SAYS THE KEY STICKS IN THE START MODE AND DOES NOT RETURN INTERMITTENTLY CAUSING THE STARTER TO GRIND
Tech Comments: 1 VERIFIED CONCERN. R AND R IGNITION LOCK CYLINDER AND LUBRICATE. START SEVERAL TIMES. COULD NOT GET TO STICK
Cust Comments: CUST SAYS THE TRUCK ROLLS EXCESSIVLYIN PARK ON THE PARK PAUL ABOUT 6 8 INCHES
Tech Comments: FLUID OK. ROAD EST SHOWS TRANS SHIFTS PROPERLY AT THIS TIME. PARK PAUL WORKS OK. NOTE, MUST APPLY E BRAKE BEFORE PUTTING
Cust Comments: CUST STATES POWER POINT INOP
Tech Comments: VERIFY CONCERN. FOUND GPS TO BE DRAWING TO MUCH AMPERAGE. FOUND BLOWN FUSE REPLACED FUSE RETESTED AND VERIFIED REPAIR
Cust Comments: CUST STATES THE TRUCK STALLS WHILE DRIVING HAD THE TRUCK TOWED IN DIAG AND REPORT
Tech Comments: TEST SYSTEM STALLING CONCERN PERFORM DIESEL DIAG FUEL SYSTEM AND INTAKE SYSTEM GOOD ROAD TEST WITH WDS MONITOR AND RECORD PIDS FOUND LOSS OF RPM SIGNAL W/STALL REPLACE CAM SHAFT SENSOR AND RETEST ALL OK
Cust Comments: SUBMIT FOR REFUND TO 07S57 ******* MOTORS INVOICE #*****11.18.2002 $100.00 DEDUCT
Old 01-19-2010, 12:17 PM
just another truck's Avatar
just another truck just another truck is offline
just another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputationjust another truck has a superb reputation
Great offer!!! Reps to you!!!!
Old 01-19-2010, 12:32 PM
hpcbmw's Avatar
Thanks Chris, great info!
Old 01-19-2010, 12:37 PM
browntown3's Avatar
browntown3 browntown3 is offline
browntown3 is starting off with a positive reputation.
1fmnu41sx1eb19157 That is for a ford excursion i plan on looking at this week.....if you could help me out i would be awesome.
Old 01-19-2010, 12:48 PM
brown
<TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>VEHICLE TOWED IN NO START CRANKS THEFT LIGHT FLASHES</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>NO GROUND IN HARNESS EEC (QUICK TEST) DIAGNOSIS</TD></TR></TBODY></TABLE>
<TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>RECALL 01S21 DUE</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>PERFORMED SAFETY RECALL</TD></TR></TBODY></TABLE>
<TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>MLDG ON PASS SIDE DOOR LOOSE.</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>CHKD MLDG & REINSTALL</TD></TR></TBODY></TABLE>
<TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>BRAKES SQUEAL WHEN IN 4X4</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>INSPECT & CLEAN FRT BRAKES</TD></TR></TBODY></TABLE>
<TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>HEADLIGHTS OUT OF ADJUSTMENT</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>CHKD & FOUND HEADLIGHT RETIANING CLIP MISSING. REPLCED CLIP</TD></TR></TBODY></TABLE>
<TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>LOCK ON LEFT FRT IS INOP</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>CHKD & REMOVED CYL & REPLACED CYL ASSY, RECODE LOCK</TD></TR></TBODY></TABLE>
<TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>PANEL ON REAR DOOR ON RT IS LOOSE</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>CHKD & FOUND MLDG CLIP BROKEN, REPLACED MLDG</TD></TR></TBODY></TABLE>
<TABLE rules=rows><TBODY><TR><TD>Cust Comments:</TD><TD colSpan=21>CUSTOMER STATES THAT VEHICLE HAS RECALL RECALL 05S28</TD></TR><TR><TD>Tech Comments:</TD><TD colSpan=21>PERFORMED RECALL 05S28 AS INSTRUCTED</TD></TR></TBODY></TABLE>
Old 01-19-2010, 01:43 PM
browntown3's Avatar
Thank you so much, I really appreciate you taking time out of your day to do that !
Old 01-19-2010, 02:59 PM
no problem
Old 01-19-2010, 04:11 PM
maevans's Avatar
maevans maevans is offline
maevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud ofmaevans has much to be proud of
Chris, When is the best time to call you about some service work ?
Don't what to bug you at work. Mark
Old 01-19-2010, 05:03 PM
im at work til 5pm, but you can call whenever, i leaving work right now, if you want give me a call and we can go over the work you need. 517-920-3048. thanks
Oasis report nards444 1999 to 2016 Super Duty 2 10-29-2015 12:34 PM
OASIS REPORT Lori Kelly 6.0L Power Stroke Diesel 1 10-15-2014 12:01 AM
NO OASIS REPORTS AVAILABLE THROUGH FTE powerstroke72 1999 to 2016 Super Duty 0 11-01-2013 07:06 PM
VIN search, Oasis Report aggiect01 1999 to 2016 Super Duty 2 08-25-2013 09:49 AM
Looking for an OASIS Report 01f350 2004 - 2008 F150 35 05-13-2008 10:50 AM
Go Back   Ford Truck Enthusiasts Forums > >
Tags
5179203048, ford, oasis, report, reports
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
