Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2007+ Expedition & Navigator
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
2007+ Expedition & Navigator 2007, 2008, 2009 and 2010 Ford Expedition and Lincoln Navigator
  #1 (permalink)
Old 01-18-2010, 07:58 PM
TexasMan77 TexasMan77 is offline
Garage is empty, add now
TexasMan77 is starting off with a positive reputation.
Unhappy CD player wont work/memory seat problems.
Hey everyone.
Just when I begin to brag about how trouble-free my 08 Expy EL EB has been the last 14 months, two small problems recently surface.
First, the CD player stopped unloading/loading CD's. I touch the "CD" button and get "NO DISC" when I know darn well there is. When I attempt to eject, or insert a CD I get a "DISK LOAD ERROR" display.
It's the same radio I had in my '06 Five Hundred SEL, that had the exact same problem.
The second concern is the memory seat only adjusts to the "1" setting (the wifes), but when I hit "2" for myself, the seat moves back about an inch, and that's it.
I'm going to take it in this week to get it looked at. Anyone else expierience these issues?
  #2 (permalink)
Old 01-18-2010, 08:16 PM
gpfarrell gpfarrell is offline
gpfarrell is starting off with a positive reputation.
Are you using any discs that you recorded?
I have no idea why, but they seem to make cd players a bit upset from time to time.
  #3 (permalink)
Old 01-19-2010, 10:26 AM
berry1234's Avatar
berry1234 berry1234 is offline
berry1234 is gaining momentum as a positive member of FTE.
Have you reset the '2' seat memory position? Many times my wife's hits the set button on accident then the 2, which puts the 2 at the current positions.
If the cd's don't have labels on them then it's just a faulty cd unit. They are not the best in the world.
__________________
1978 F250 Lariat 4x2
2008 Expedition Eddie Bauer 4x2
  #4 (permalink)
Old 01-19-2010, 08:09 PM
The discs aren't recorded.
And when I open the door, the CD player makes a funny noise, similar to the one it makes when it's shuffling from disc to disc, wierd.
I reset the memory seat to my settings last night, when the wife returns from the store I'll have to check it.
  #5 (permalink)
Old 01-20-2010, 10:52 AM
berry1234's Avatar
I can't recall how the memory works with two different keys. I want to say each key will retain the memory settings of the 1 position. So you setting it with your key may not work.
If the truck is under warranty get the cd unit swapped out. You can try disconnecting your battery for a couple of minutes, then try to eject your discs. If that doesn't help, you would have to take the unit apart to remove the cd's. If the truck is out of warranty, there are many used OEM radios on ebay for around $100 and they are easy to remove/install.
__________________
  #6 (permalink)
Old 01-22-2010, 07:41 AM
buzzard's Avatar
buzzard buzzard is offline
buzzard is starting off with a positive reputation.
Texasman, my 2008 has done the exact same thing a few times, loses seat memory and cd player "shuffles" for no apparent reason. Prob is it never does it when the truck's in the shop so dealership doesn't have a fix. Let us know if you find the root problem.
Also, and probably related, my abs sometimes activates for no reason and the traction control has activated in dry (no slip) conditions. I have a suspicion that the electrical module is the culprit.
__________________
Jim
Mac Haik is a Joke
1968 F250 CS, 390
Pebble Beige/Wimbledon White
2008 4x4 EB Expedition, White
  #7 (permalink)
Old 01-22-2010, 10:45 AM
berry1234's Avatar
Quote:
TSB 08-20-8
10/13/08
STEERING WHEEL ANGLE CIRCUIT AND/OR SIGNAL
FAILURE - C1277-C1278 - BUILT ON/OR BEFORE
4/10/2008
FORD:
2007-2008 Expedition
LINCOLN:
2007-2008 Navigator
This article supersedes TSB 08-10-3 to update the Part List and Service procedure.
ISSUE
Some 2007-2008 Expedition and Navigator vehicles built on or before 4/10/2008 may exhibit a traction control light (TCL) on with diagnostic trouble codes (DTCs) C1277 and/or C1278 (steering wheel angle 1 and 2 circuit failure and/or signal faulted).
ACTION
Follow the Service Procedure steps to correct the condition.
SERVICE PROCEDURE
1. Check to see if the steering wheel rotation (SWR) sensor wiring near the connector has come in contact with or is touching the brake pedal bracket. Vibration of the harness may cause interruption in the SWR signal.
a. If yes, go to Step 2.
b. If no, do not continue with this procedure. Refer to normal diagnosis in the Workshop Manual (WSM), Section 206-09.
2. Repair any chafing that may have occurred.
3. Move the harness towards the driver's side of the vehicle and tuck in front of the 14401 harness above the steering column. Use a tie strap to secure in place.
4. Replace the SWR sensor following WSM, Section 206-09.
Parts Block
WARRANTY STATUS: Eligible Under Provisions Of New Vehicle Limited Warranty Coverage
IMPORTANT : Warranty coverage limits/policies are not altered by a TSB. Warranty coverage limits are determined by the identified causal part.
OPERATION DESCRIPTION TIME
082008A 2007-2008 Expedition, 0.7 Hr.
Navigator: Replace The
Steering Wheel Rotation
Sensor, Includes Time To
Reposition Harness, Check
DTCs, Repair Wires If
Required, And Calibrate
New Sensor. (Do Not Use
With 12650D, 14200A)
DEALER CODING
CONDITION
BASIC PART NO. CODE
14401 12
__________________
  #8 (permalink)
Old 01-25-2010, 09:29 PM
OK, I reset the memory seat to my setting and that fixed it, no problems since.
I'll take the truck in this week to have the CD player replaced.
The shuffling sound is still heard whenever I open the door.
  #9 (permalink)
Old 01-26-2010, 08:57 PM
buzzard's Avatar
My stereo did the shufflling thing this morning when I opened my door. Also, both driver seat memory settings were gone.
__________________
Jim
Mac Haik is a Joke
1968 F250 CS, 390
  #10 (permalink)
Old 01-26-2010, 10:53 PM
Taking it to the Ford dealer Friday morning to get the radio replaced.
  #11 (permalink)
Old 01-27-2010, 10:38 AM
berry1234's Avatar
Can you set the seat, then move it manually then hit the memory button and it won't go to what you just saved?
Some glitch for sure. I would take it in.
__________________
  #12 (permalink)
Old 05-21-2012, 12:58 PM
tahoetoo tahoetoo is offline
tahoetoo is starting off with a positive reputation.
2007 Navigator Memory Seat Problem
I have a problem with my seat memory also. Memory Number 1 is set, but the seat does not go back when I take the key out, and I can not set memory #2. What do you think is wrong?
Tags
03, 2005, 500, aviator, cd, error, expedition, f250, ford, lincoln, load, player, repair, reset, wont, work
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
