P0705
P0705
So the truck im interested in is a 2003 F250 with the 7.3 in it. well I took it to the dealor ship, so they could do a full diagnostic check on it. Also I had a few questions for them. The OFF on the overdrive button kept flashing. So when they were done they said that it was a P0705 code, because the Torque Converter was slipping, and the repair was $1200. When I looked up P0705 it says Transmission Range Sensor Circuit Malfunction (PRNDL input)?? Whats the deal with that? TR Sensor does not sound like torque converter to me..
Can anyone educate me on this??
I'm not a trans guy but here is a bump for you man.
Bump...... Let us know how this turns out. Good luck.
P0705{1}{2}
TR Sensor Circuit Fault
P0705{3}{4}
List of Codes:
P0107
BARO Circuit Out Of Range Low
P0108
BARO Circuit Out Of Range High
P0112
IAT Circuit Out Of Range Low
P0113
IAT Circuit Out Of Range High
P0122{1}
AP Sensor Signal ORL
P0123{1}
AP Sensor Signal ORH
P0195{5}
EOT Above/Below KOER Limits
P0196{5}
EOT Sensor Circuit <NOBR style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_10_0>Performance</NOBR>
P0197{1}
EOT Circuit Out Of Range Low
P0198{1}
EOT Circuit Out Of Range High
P0219{5}
Excessive Engine RPM
P0220{1}
Idle Validation Switch Fault
P0221{1}
P0230{5}
<NOBR style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_16_0>Fuel</NOBR> Pump Monitor Circuit
P0231{5}
Fuel <NOBR style="COLOR: darkgreen; FONT-SIZE: 100%; FONT-WEIGHT: normal" id=itxt_nobr_17_0>Pump</NOBR> Monitor Circuit
P0232{5}
Fuel Pump Monitor Circuit
P0235{1}{5}
MAP Inactive Signal
P0236{1}{2}
Turbo Boost Sensor A Circuit Performance
P0236{1}{3}
P0237{1}{2}
P0237{1}{3}
Turbo Boost Sensor A Circuit Low Input
P0238{1}{3}
Turbo Boost Sensor A Circuit High Input
P0261{1}{2}
Low Side Short To Ground Injector Circuit No. 1
P0261{1}{3}
Injector Circuit Low, No. 1 Cylinder
P0262{2}
Low Side Short To Battery Injector Circuit No. 1
P0262{3}
Injector Circuit High, No. 1 Cylinder
P0263
Cylinder Fault No. 1, CCT
P0264{1}{2}
Low Side Short To Ground Injector Circuit No. 2
P0264{1}{3}
Injector Circuit Low, No. 2 Cylinder
P0265{2}
Low Side Short To Battery Injector Circuit No. 2
P0265{3}
Injector Circuit High, No. 2 Cylinder
P0266
Cylinder Fault No. 2, CCT
P0267{1}{2}
Low Side Short To Ground Injector Circuit No. 3
P0267{1}{3}
Injector Circuit Low, No. 3 Cylinder
P0268{2}
Low Side Short To Battery Injector Circuit No. 3
P0268{3}
Injector Circuit High, No. 3 Cylinder
P0269
Cylinder Fault No. 3, CCT
P0270{1}{2}
Low Side Short To Ground Injector Circuit No. 4
P0270{1}{3}
Injector Circuit Low, No. 4 Cylinder
P0271{2}
Low Side Short To Battery Injector Circuit No. 4
P0271{3}
Injector Circuit High, No. 4 Cylinder
P0272
Cylinder Fault No. 4, CCT
P0273{1}{2}
Low Side Short To Ground Injector Circuit No. 5
P0273{1}{3}
Injector Circuit Low, No. 5 Cylinder
P0274{2}
Low Side Short To Battery Injector Circuit No. 5
P0274{3}
Injector Circuit High, No. 5 Cylinder
P0275
Cylinder Fault No. 5, CCT
P0276{2}
Low Side Short To Ground Injector Circuit No. 6
P0276{1}{3}
Injector Circuit Low, No. 6 Cylinder
P0277{2}
Low Side Short To Battery Injector Circuit No. 6
P0277{3}
Injector Circuit High, No. 6 Cylinder
P0278
Cylinder Fault No. 6, CCT
P0279{1}{2}
Low Side Short To Ground Injector Circuit No. 7
P0279{1}{3}
Injector Circuit Low, No. 7 Cylinder
P0280{2}
Low Side Short To Battery Injector Circuit No. 7
P0280{3}
Injector Circuit High, No. 7 Cylinder
P0281
Cylinder Fault No. 7, CCT
P0282{1}{2}
Low Side Short To Ground Injector Circuit No. 8
P0282{1}{3}
Injector Circuit Low, No. 8 Cylinder
P0283{2}
Low Side Short To Battery Injector Circuit No. 8
P0283{3}
Injector Circuit High, No. 8 Cylinder
P0284
Cylinder Fault No. 8, CCT
P0301{5}
Injector Driver Circuit
P0302{5}
P0303{5}
P0304{5}
P0305{5}
P0306{5}
P0307{5}
P0308{5}
P0340
Inactive CMP Sensor Circuit
P0341{2}
CMP Noise Rejection
P0341{1}{3}
CMP Sensor Circuit Performance
P0344{2}
CMP/SYNC Counts
P0344{1}{3}
CMP Sensor Circuit Intermittent
P0380{2}
GP Relay Output Circuit Fault
P0380{3}
GP Circuit Malfunction
P0381{2}
GP Lamp Output Circuit Fault
P0381{3}
GP Indicator Circuit Malfunction
P0460{3}
Fuel Tank Level Indicator Circuit Malfunction
P0470
EBP Sensor Circuit Malfunction
P0471
EBP Sensor Circuit Performance
P0472
EBP Circuit Out Of Range Low
P0473
EBP Circuit Out Of Range High
P0475{2}
EPR Circuit Fault
P0475{3}
EP Control Valve Malfunction
P0476{2}
EBP Pressure Above/Below Desired
P0476{3}
EP Control Valve Performance
P0478
Excessive Backpressure
P0500
Vehicle Speed Sensor Fault
P0541
Manifold Intake Air Heater
P0542
P0560{2}
B+, Volt Too Low For CCT Test
P0560{3}
System Voltage Malfunction
P0562{2}
Battery Voltage Below Normal
P0562{3}
P0563{2}
Battery Voltage Above Normal
P0563{3}
P0565{2}
Speed Control ON Not Pressed
P0565{3}
Cruise‘‘ON’’ Signal Malfunction
P0566{2}
Speed Control OFF Not Pressed
P0566{3}
Cruise‘‘OFF’’ Signal Malfunction
P0567{2}
Speed Control RESUME Not Pressed
P0567{3}
Cruise‘‘ RESUME’’ Signal Malfunction
P0568{2}
Speed Control SET Not Pressed
P0568{3}
Cruise‘‘SET’’ Signal Malfunction
P0569
Speed Control COAST Not Pressed
P0569
Cruise‘‘COAST’’ Signal Malfunction
P0571{2}
Brake Pedal Applied Switch Fault
P0571{3}
Brake Switch Circuit A Malfunction
P0603
KAM Memory Loss
P0605
PCM ROM Test Fault
P0606
PCM Inactive Background Fault
P0640
P0703{2}
Brake On/Off Switch Circuit Fault
P0703{3}
Brake Switch Circuit B Malfunction
P0704
CPP Switch Input Circuit Fault
P0705{1}{2}
P0705{3}{4}
P0707{1}{2}
TR Sensor Circuit Low Input
P0707{3}{4}
P0708{1}{2}
TR Sensor Circuit High Input
P0708{3}{4}
P0712
Transmission Fluid Temperature Sensor Circuit Low Input
P0713
Transmission Fluid Temperature Sensor Circuit High Input
P0715{5}
Transmission Concern
P0717{5}
P0718{5}
P0720{5}
P0721{5}
P0722{5}
P0732{5}
P0733{5}
P0741{2}
TCC Solenoid Fault
P0741{3}
TCC Solenoid Circuit Performance
P0743
TCC System Electrical Failure
P0750
Shift Solenoid No. 1 Fault
P0751
Shift Solenoid A Performance
P0755
Shift Solenoid No. 2 Fault
P0756
Shift Solenoid B Performance
P0760
Shift Solenoid C Malfunction
P0781{1}{2}
1–2 Shift Error
P0781{3}{4}
1–2 Shift Malfunction
P0782{1}{2}
2–3 Shift Error
P0782{3}{4}
2–3 Shift Malfunction
P0783{1}{2}
3–4 Shift Error
P0783{3}{4}
3–4 Shift Malfunction
P1000
OBD II Monitor Checks Incomplete, More Driving Required
P1105{5}
Charging System Concern
P1106{5}
P1107{5}
P1108{5}
P1111{2}
System Pass
P1111
System Pass, 49 State Except 1998–98.5 Econoline
P1118{3}
MAT Sensor Fault
P1119{3}
MAT Sensor Fault
P1139{3}
WIF Sensor Fault
P1140{3}
WIF Sensor Fault
P1184
EOT Sensor Circuit Performance
P1209
Injection Control System Pressure Peak Fault
P1210
ICP Sensor Fault
P1211{2}
ICP Pressure Is Above/Below Desired, Faulty IPR Valve
P1211{1}{3}
ICP Pressure Uncontrollable, Pressure Above/Below Desired
P1212{2}
ICP Higher That Expected KOEO
P1212{1}{3}
ICP Voltage Not At Expected Level
P1218
CID Stuck High
P1219
CID Stuck Low
P1247
Turbo Boost Pressure Low
P1248
Turbo Boost Pressure Not Detected
P1249{3}
Waste Gate Control Solenoid
P1250{5}
P1261–1268
High To Low Side Short, Cylinders No.1–8
P1271–1278
High To Low Side Open, Cylinders No.1–8
P1280{2}
ICP Circuit Out Of Range, Low
P1280{1}{3}
P1281{2}
ICP Circuit Out Of Range, High
P1281{1}{3}
P1282
Excessive ICP Pressure
P1283{2}
IPR Circuit Fault
P1283{1}{3}
IPR Circuit Failure
P1284
Aborted KOER, ICP Fault
P1291
High Side No. 1 (RH) Short To Ground Or B+
P1292
High Side No. 2 (LH) Short To Ground Or B+
P1293
High Side Open Bank No. 1 (RH)
P1294
High Side Open No. 2 (LH)
P1295{1}
Multiple Faults On Bank No. 1 (RH)
P1296{1}
Multiple Faults On Bank No. 2 (LH)
P1297
High Sides Shorted Together
P1298
IDM Fault
P1316
Injector Circuit/IDM Codes Detected
P1391
GP Circuit Low Input Bank No. 1 (RH)
P1392
GP Circuit High Input Bank No. 1 (RH)
P1393
GP Circuit Low Input Bank No. 2 (LH)
P1394
GP Circuit High Input Bank No. 2 (LH)
P1395
GP Monitor Fault Bank No. 1
P1396
GP Monitor Fault No. 2
P1397
System Voltage Out Of Self Test Range
P1464
A/C On During KOER Or CCT Test
P1501
Vehicle Moved During KOER
P1502{3}
Invalid Self Test-APCM Functioning
P1531
Invalid CCT Test, Accelerator Pedal Movement
P1536
Parking Brake Applied Fault
P1660
Output Circuit Check Signal High
P1661
Output Circuit Check Signal Low
P1662
IDM EN Circuit Fault
P1663
FDCS Circuit Fault
P1667
CID Circuit Fault
P1668
PCM/IDM Diagnostic Communication Error
P1670{3}
IDM Electronic Feedback
P1690{5}
P1702{5}
P1704
Digital TRS Failed To Transition State
P1705
TR Sensor Out Of Self Test Range
P1706{1}{2}
High Vehicle Speed In Park
P1706{3}{4}
P1711
TFT Sensor Out Of Self Test Range
P1713{5}
P1714
Shift Solenoid A Inductive Signature Malfunction
P1715
Shift Solenoid B Inductive Signature Malfunction
P1718{5}
P1727
Coast Clutch Solenoid Inductive Signature Malfunction
P1728{1}{2}
Transmission Slip Error
P1728{3}{4}
Transmission Slip Error, Converter Clutch Failed
P1729
4x4 Low Switch Error
P1740
TCC Inductive Signature Malfunction
P1742
TCC Failed On
P1744
TCC System Performance
P1746
EPC Solenoid Open Circuit
P1747
EPC Solenoid Short Circuit
P1748{1}{2}
EPC Fault
P1748{3}{4}
EPC Malfunction
P1751
P1754
Coast Clutch Solenoid Circuit Fault
P1756
P1760{5}
P1779
TCIL Circuit Out Of Self Test Range
P1780
TCS Circuit Out Of Self Test Range
P1781
4x4 Low Circuit Out Of Self Test Range
P1783{1}{2}
Transmission Over Temperature Condition
P1783{3}{4}
P1902{3}
Kickdown Solenoid Relay
P1903{3}
P1904{3}
{1}—MIL lit when fault is present.
{2}—1997 models.
{3}—1998–2001 models.
{4}—Transmission Control Indicator Lamp (TCIL) lit when fault is present.
{5}—2001 & Earlier models.
P0705{1}{2}
P0705{3}{4}
List of Codes:
P0107
P0108
P0112
P0113
P0122{1}
P0123{1}
P0195{5}
P0196{5}
P0197{1}
P0198{1}
P0219{5}
P0220{1}
P0221{1}
P0230{5}
P0231{5}
P0232{5}
P0235{1}{5}
MAP Inactive Signal
P0236{1}{2}
P0236{1}{3}
P0237{1}{2}
P0237{1}{3}
P0238{1}{3}
P0261{1}{2}
P0261{1}{3}
P0262{2}
P0262{3}
P0263
P0264{1}{2}
P0264{1}{3}
P0265{2}
P0265{3}
P0266
P0267{1}{2}
P0267{1}{3}
P0268{2}
P0268{3}
P0269
P0270{1}{2}
P0270{1}{3}
P0271{2}
P0271{3}
P0272
P0273{1}{2}
P0273{1}{3}
P0274{2}
P0274{3}
P0275
P0276{2}
P0276{1}{3}
P0277{2}
P0277{3}
P0278
P0279{1}{2}
P0279{1}{3}
P0280{2}
P0280{3}
P0281
P0282{1}{2}
P0282{1}{3}
P0283{2}
P0283{3}
P0284
P0301{5}
P0302{5}
P0303{5}
P0304{5}
P0305{5}
P0306{5}
P0307{5}
P0308{5}
P0340
P0341{2}
CMP Noise Rejection
P0341{1}{3}
P0344{2}
CMP/SYNC Counts
P0344{1}{3}
P0380{2}
P0380{3}
P0381{2}
P0381{3}
P0460{3}
P0470
P0471
P0472
P0473
P0475{2}
EPR Circuit Fault
P0475{3}
P0476{2}
P0476{3}
P0478
P0500
P0541
P0542
P0560{2}
P0560{3}
P0562{2}
P0562{3}
P0563{2}
P0563{3}
P0565{2}
P0565{3}
P0566{2}
P0566{3}
P0567{2}
P0567{3}
P0568{2}
P0568{3}
P0569
P0569
P0571{2}
P0571{3}
P0603
KAM Memory Loss
P0605
PCM ROM Test Fault
P0606
P0640
P0703{2}
P0703{3}
P0704
P0705{1}{2}
P0705{3}{4}
P0707{1}{2}
P0707{3}{4}
P0708{1}{2}
P0708{3}{4}
P0712
P0713
P0715{5}
P0717{5}
P0718{5}
P0720{5}
P0721{5}
P0722{5}
P0732{5}
P0733{5}
P0741{2}
TCC Solenoid Fault
P0741{3}
P0743
P0750
P0751
P0755
P0756
P0760
P0781{1}{2}
1–2 Shift Error
P0781{3}{4}
P0782{1}{2}
2–3 Shift Error
P0782{3}{4}
P0783{1}{2}
3–4 Shift Error
P0783{3}{4}
P1000
P1105{5}
P1106{5}
P1107{5}
P1108{5}
P1111{2}
System Pass
P1111
P1118{3}
MAT Sensor Fault
P1119{3}
MAT Sensor Fault
P1139{3}
WIF Sensor Fault
P1140{3}
WIF Sensor Fault
P1184
P1209
P1210
ICP Sensor Fault
P1211{2}
P1211{1}{3}
P1212{2}
P1212{1}{3}
P1218
CID Stuck High
P1219
CID Stuck Low
P1247
P1248
P1249{3}
P1250{5}
P1261–1268
P1271–1278
P1280{2}
P1280{1}{3}
P1281{2}
P1281{1}{3}
P1282
P1283{2}
IPR Circuit Fault
P1283{1}{3}
IPR Circuit Failure
P1284
P1291
P1292
P1293
P1294
P1295{1}
P1296{1}
P1297
P1298
IDM Fault
P1316
P1391
P1392
P1393
P1394
P1395
P1396
P1397
P1464
P1501
P1502{3}
P1531
P1536
P1660
P1661
P1662
P1663
FDCS Circuit Fault
P1667
CID Circuit Fault
P1668
P1670{3}
P1690{5}
P1702{5}
P1704
P1705
P1706{1}{2}
P1706{3}{4}
P1711
P1713{5}
P1714
P1715
P1718{5}
P1727
P1728{1}{2}
P1728{3}{4}
P1729
P1740
P1742
TCC Failed On
P1744
P1746
P1747
P1748{1}{2}
EPC Fault
P1748{3}{4}
EPC Malfunction
P1751
P1754
P1756
P1760{5}
P1779
P1780
P1781
P1783{1}{2}
P1783{3}{4}
P1902{3}
P1903{3}
P1904{3}
{2}—1997 models.
on
P0705 Digital TR Sensor Digital TR circuit failure. Digital TR circuits, indicating an invalid pattern in TR_D. Condition caused by a short to ground or an open in TR4, TR3A, TR2, and/or TR1 circuits. Increase in EPC pressure (harsh shifts). Defaults to (D) or D for all gear positions. In (D) position transmission stuck in D or manual 2. May flash MIL
This code is related to the switch, on the gear selector shaft on the transmission itself, or its wiring.
on
P0740 TCC solenoid TCC solenoid circuit failure. TCC solenoid circuit fails to provide voltage drop across solenoid. Circuit open or shorted or PCM driver failure during KOEO. Short circuit — engine stalls in DRIVE or MANUAL 2 at idle with brake applied. Open circuit — TCC never engaged. May flash TCIL.
P0741 TCC TCC slippage detected. The PCM picked up an excessive amount of TCC slippage during normal vehicle operation. TCC slippage erratic or no torque converter clutch operation. May flash TCIL
on
I would say the codes would need to be cleared and see what returns after more driving. I don't know how much slippage would set a code. It may be enough and not really be able to feel. Seems like you would be able to see a rise in the tach when accelerating, after lock up, if it were slipping that bad.
BogginDave
03-30-2016 04:09 PM
