1978 WHEELBASE
1978 WHEELBASE
John,
I am aware of how you measure wheelbase, but I don't have a '78 swb to measure. I have a
'49 F-1 Ford that I am going to install on a 4x4 chassis; therefore, the distance between the brakes does make a difference. I am trying to gather information on which chassis would be best to install my '49 body on.
Randy
Randy
The following users liked this post:
1978 WHEELBASE
Let's make this real simple - Whenever you attempt to mate 2 or more components that were never designed to be put together you have to modify one or both of the existing components to make them work together. So as in the above posts it doesn't matter what running gear you start with it is still going to have to be torn apart and rebuilt to make it fit the body you intend to put on top of it. Get out your tape, use some common sense, and quit whining if you don't like the advice YOU asked for.
Trail Rider
Trail Rider
1978 WHEELBASE
1) I did not ask for advice, I asked for specifications. 2) I don't whine.
3)Anyone that would start a project without making sure they had as closely matched components as are readily available would be a damn idiot.
4)The only useful information I got from here was from Mike and I appreciate it.
5)I posted the same request for SPECIFICATIONS on a different website today and had the exact SPECIFICATIONS that I asked for four hours later!!!!! I won't be back here for any more of your "ADVICE"!!!!!!!!!!!!!!!
1978 WHEELBASE
I wonder if this guy has any idea that the 49 had a wheel base of 114 inches which isn't too far off (within an inch) from many later model F100s. But heck, don't worry about the most important thing, the track width. Without paying attention to the width of the axles, he could end up narrowing alot of steering and running gear (tough and pricey) as opposed to shortening a frame and driveshaft ( not as bad). Maybe he is building a plastic model for his older brother for Xmas. Oh well, I hate the chat room format; hope he ends up on that crappy classic truck bb.
